-   -   Beep, Beep, Beep????? (https://www.offshoreonly.com/forums/general-boating-discussion/139711-beep-beep-beep.html)
fatdaddy 09-05-2006 09:41 PM
I have an '03 33 Baja Outlaw w/ 496HO's. While running pretty hard in the ocean in 2- 4 ft. had the whistles come on. Checked all gauges, all fine and immediately shut down. Turned batteries off and checked all fluids, all good. Turned batt.'s back on and off I went for another 1 hr. and on it came again. Followed same procedure and all was well? I guess again. Ran the boat again this past weekend and same thing happened. Any ideas? TIA.
Loan Ranger 09-06-2006 07:20 AM
Re: Beep, Beep, Beep?????
Could be the CO monitor. Try pushing the test button. Mine beeps periodically.
SLINGSHOT 09-06-2006 07:29 AM
water pressure sensor.....
BillR 09-06-2006 07:31 AM
Outdrive oil level sensor.
I rough water, mine sometimes beeps.
CAP071 09-06-2006 07:51 AM
Stay out of the Ocean :D
wrinkleface 09-06-2006 08:52 AM
On a Formula I had, the bilge pump under the cabin entry step "it was stuck on". There is a little button to push or slide to get it "unstuck"! good luck
fatdaddy 09-06-2006 09:10 PM
It is not periodic. I've heard what you are referring to at home in a battery operated CO monitor. Thanks anyway.
fatdaddy 09-06-2006 09:11 PM
Hey Mike, I don't think so, water press. gauges indicated good pressure. Any other ideas?
fatdaddy 09-06-2006 09:13 PM
I thought same thing. Shut down and checked, all good. I should note that the last time out w/ this occurrence was in flat water.
tomtbone1993 09-06-2006 09:13 PM
fuel sensor??? for fumes??
fatdaddy 09-06-2006 09:14 PM
Interesting? But if this was the case wouldn't it stay continuously beeping until I got it unstuck?
Magicfloat 09-06-2006 10:13 PM
Most of the time it is the gear lube monitor. But if you eliminate that,there are 27 other things that set off the beep. Eliminate the gear lube ,then get a Merc dealer to plug in his scan tool.Shouldn't cost a lot,and then you will know for sure. But 99% of our problems are gear lube. :p
fatdaddy 09-06-2006 10:42 PM
I agree. Will probably pull boat this weekend, summer is coming to a quick end in NJ, and will have it scanned when sch'd for winterization.
