-   -   Used boat values and engine hp (https://www.offshoreonly.com/forums/general-boating-discussion/141082-used-boat-values-engine-hp.html)
onesickpantera 09-21-2006 08:11 PM
When looking up used boat values what hp do you enter for a HP500? There is a BIG difference in value between 470 and 500hp!
buck183 09-21-2006 09:41 PM
Re: Used boat values and engine hp
I thought a 500HP was around 470-480 HP?
Ca$hed Out 09-21-2006 09:45 PM
I believe 475 is the official number insurance companies, etc use
onesickpantera 09-21-2006 09:48 PM
A 500HP is rated at 500 at the crank and 470 at the prop. So, do you enter 470 or 500 when getting boat values? :confused:
buck183 09-21-2006 09:59 PM
Hmmm? Dunno...I never did very well on multiple choice.
What about a 502 Mag? They are rated for 415HP at the prop correct? Why can we quote this engine for values or insurance at prop HP and the 500HP has to be quoted at the crank?
I've just always thought of it as a 480HP or so engine.
onesickpantera 09-21-2006 10:03 PM
Oh for insurance I would think it's always 470hp! :D
For values it's confusing since all the black motors are prop hp and the blue motors are crank hp. :confused: And there is a BIG difference between 426-470hp and 471-500hp!
Griff 09-22-2006 12:49 AM
Use the 471-500hp number.
Book value is only an estimate anyway and is for banks to use. They should also include hours as a factor to determine the value of a boat. The same boat with 500 hours on a set of 500's is worth a lot less than one with 200hrs.
onesickpantera 09-22-2006 06:23 AM
Griff, I understand it's just a guide. I was just wondering what engine hp numbers to use to set the baseline. Thanks.
So, another question. With a 502 Mag MPI(415 pshp) do you use 400-425hp or 426-470hp since technically the motor has 445 crank hp?
BajaRunner 09-22-2006 08:31 AM
415
onesickpantera 09-22-2006 08:35 AM
I emailed NADA so hopefully they can clarify. Based on their website I think you always enter the ENGINE hp. Meaning a 502 Mag would be 445. But I want to be sure.
BY U BOY 09-22-2006 09:11 AM
IF YOU ARE SELLING USE THE HIGHER HP.
IF BUYING USE THE LOWER HP # :evilb:
cosmic12 09-22-2006 09:14 AM
don't depend on N.A.D.A. most banks or dealers don't use it. They use A.B.O.S.
onesickpantera 09-22-2006 09:22 AM
I'm just using NADA as a guide. None of the books are a "Bible". ABOS uses hoices for hp too.
FYI, my bank uses NADA and most of our local banks do as well.
onesickpantera 09-22-2006 09:28 AM
Good point! :D
hpoffshore 09-22-2006 09:33 AM
Actually, the majority of my lenders look to the NADA for loan values; and they work off of the "used trade-in $#". If there's no data in NADA, they will default either BUC or ABOS. ABOS doesn't quantify any option costs, but they do better with motor hp ratings, using actual $ values for the various engine packages that were available in that hull. The HP500's and 500EFI's value @ 470 hp, 525SC's value @ 490, and I believe 525EFI's value @ 500.
onesickpantera 09-22-2006 09:51 AM
Thanks for the replies but now I am more confused than ever! :D
The reason for this question is I am trying to determine how much more a used boat would be would be worth with an HP500EFI compared to a 502 Mag EFI.
hpoffshore 09-22-2006 10:42 AM
It would be the $ difference between the boat with 470hp and the boat with 415 hp. As I said, ABOS gives you the actual $ of the boat with that particular motor/power; NADA has a $ chart for the upgrade from the boat with base hp, to the upgrade horsepower that YOU specify. You can access NADA online(BUC, too). If you want ABOS $'s, I'll be happy to run them for you. PM me.
onesickpantera 09-22-2006 11:11 AM
No need for that at this time but I appreciate your offer. I may take you up on it later.
NADA just emailed me back and said to use CRANK HP. But, the more I look at their site the more that doesn't make sense. "Standard motors" are popping up at 385hp a lot which we all know is a 454 Mag MPI. :confused:
hpoffshore 09-22-2006 11:15 AM
Exactly..........
