-   -   New Citation Turbine Video (https://www.offshoreonly.com/forums/general-boating-discussion/143093-new-citation-turbine-video.html)
Fountain38SC 10-18-2006 04:03 PM
You need to watch more than the first few minutes. It is boating related, just not as fast as I'd expect for a turbine. :evilb:
http://www.break.com/index/plane_crashes_into_lake.html
CigDaze 10-18-2006 04:06 PM
Re: New Citation Turbine Video
I saw that earlier this morning. I love the engines running full tilt with the plane in the water - did they really think they were just going to taxi it out of the lake? :eek: :rolleyes:
On May 15, 2005, at 1548 eastern daylight time, a Danish-registered
(OY-JET), Cessna Citation 525A, was substantially damaged during a runway
overrun at Atlantic City Municipal Airport/Bader Field (AIY), Atlantic
City, New Jersey. The certificated private pilot received minor injuries,
and three passengers received no injuries. Visual meteorological conditions
prevailed and an instrument flight rules (IFR) flight plan was filed for
the flight which originated at the Burlington International Airport (BTV),
Burlington, Vermont. The business flight was conducted under 14 CFR Part 91.
The pilot reported to a Federal Aviation Administration (FAA) inspector,
that he performed "one circle" around the airport, observed the windsock,
and then performed a landing on runway 11. During the landing roll,
approximately 2/3 down the runway, the pilot "lost the brakes," and was
unable to stop on the remaining runway. The airplane then continued off the
departure end of the runway and impacted the water.
A review of recorded radar data and air traffic control (ATC)
communications revealed the pilot contacted Atlantic City (ACY) Approach
Control at 1538, and stated he was inbound to "alpha charlie yankee." The
pilot was instructed to descend to an altitude of 2,000 feet, and fly
heading 220 degrees.
At 1540, ATC instructed the pilot to "proceed direct Bader, descend and
maintain 1,500 feet. Expect visual approach." The pilot read back the
instructions, stating, "thank you, direct Bader, descend to 1,500."
At 1544, ATC informed the pilot that "the airport is 12 o'clock and 4
miles." The pilot responded that he had the airport in sight, and the
controller then cleared the pilot for a "visual approach at Bader airport."
Radar data indicated that the airplane was at an altitude of 800 feet, at
1545, continuing on a heading of 220 degrees. About 1 minute later, the
airplane made a 360-degree right turn, and rolled out on it's previous
heading of 220-degrees. At 1547:10, the airplane crossed abeam the
departure end of runway 11, at AIY, at an altitude of 100 feet. The
airplane then continued on a westerly (downwind) heading and climbed to an
altitude of 300 feet.
The airplane then initiated a right turn back toward runway 11, at an
altitude of approximately 200 feet. During the turn, the airplane's
groundspeed was approximately 180 knots.
At 1548:42, the airplane was at an altitude of 200 feet, 1.24 nautical
miles from the approach end of runway 11, with a groundspeed of 155 knots.
Over the next 10 seconds, the airplane's altitude decreased to 0 feet, and
the airspeed decreased to 140 knots. The last radar return was recorded
approximately 1,000 feet beyond the approach end of runway 11, at an
airspeed of 128 knots.
A witness, who was an employee at AIY, was inside a trailer, located about
400 feet to the right of the midfield point of runway 11, at the time of
the accident. The witness was in communication with a Cessna 182, on a
downwind leg of the traffic pattern for runway 29, when he looked out the
window and observed the accident airplane make a "low pass on runway 29
with a climbing right turn out." The witness went outside the trailer and
observed the accident airplane touchdown "about halfway down" runway 11.
The airplane appeared to slow as it approached the end of the runway;
however, it did not stop, and subsequently impacted the water. The witness
further reported that the pilot of the accident airplane did not
communicate any intentions on the UNICOM frequency.
Several other witnesses reported that as the airplane touched down, they
thought braking was occurring, since smoke was coming from the airplane's
tires.
Examination of a video recording, which was taken by a witness at the
airport, revealed the airplane touched down about 800-1,000 feet beyond the
approach end of runway 11. The video also displayed the windsock at the
airport, and according to the witness, it indicated a tailwind at 10-15
knots.
The airplane was examined by an FAA inspector after the accident. According
to the inspector, the brake system and emergency brake system were
functionally checked, and no abnormalities were noted. The anti-skid system
could not be tested, due to salt water damage. Examination of the emergency
brake system revealed it had not been used, and the nitrogen bottle gauge
indicated 1,800 psi. The flap selector was in the "ground" position, but
the indicator was in the 15 degree position. The left throttle lever was
observed in idle cut off, and the right throttle lever was bent to the
right at the idle stop.
Examination of the runway revealed tread marks beginning approximately
two-thirds down the runway, and continuing off the departure end into the
grass and dirt.
The winds reported at Atlantic City International Airport (ACY), 9 miles to
the northwest, at 1554, were from 280 degrees at 9 knots.
A review of the FAA Airport/Facility Directory for the Northeast U.S.,
revealed the following notation listed in the Airport Remarks section of
the Atlantic City/Bader Field Airport entry, "Arpt CLOSED to jet traffic."
Additionally, runway 11 was a 2,948 foot-long, 100 foot-wide, asphalt
runway.
Additionally, the airport diagram for Bader Field, was observed attached to
the pilot's control column after the accident. A notation, which read,
"airport closed to jet aircraft" was observed on the diagram.
According to the Cessna 525A Landing Distance Chart, an airplane with a
landing weight of 11,400 pounds required 3,000 feet of landing distance, in
a no wind situation. With a 10 knot tailwind, the airplane required 3,570
feet of landing distance.
CBR 10-18-2006 04:42 PM
Son, dat dere is one of them cigar boats with the boat/plane option.
Fountain38SC 10-18-2006 05:11 PM
Can U say PILOT ERROR?
Spine Tingler 10-18-2006 07:49 PM
That's great. Sometimes people amaze me!
rocketboat 04-02-2007 12:15 AM
Well... at least he coulda fired up both engines and tried for a straight line... mighta even got er up... dare I say it... on Plane... (OOohhhhh....)
