Need Survey Wood Bridge,VA
Posting this for Mike. He needs a survey done asap in Wood Bridge,VA. He wants someone who is good and can do comp/leak down test on a 2004 38' boat w/ twin Merc 525 Efi's. Also moisture test. Call 954-709-7191.
Re: Need Survey Wood Bridge,VA
call one of the large lenders like Beacon Credit. They have guys all over the Country that do surveys for them and can provide you with a few names
PM HUGH ............ "HPOFFSHORE" HE WORKS FOR A PERFORMANCE DEALER AROUND THIS AREA AND I'M SURE WOULD BE ABLE TO HELP YOU.... HOPE THIS HELPS, PAT |
Call either Hugh as suggested earlier or Frank Marchone (Active Thunder) for a suggestion. Frank: 410-320-5307 |
Call Fred at True Headings 703-517-1281. I know he has a moisture meter and he might know someone to do the leak-down test. He does a real professional survey. I just had mine done about a month ago. Tell him Mick sent you. Hope this helps!! :chimp:
| All times are GMT -5. The time now is 06:50 AM. |
