Sit down vs. stand up seating >
Old 11-17-2006, 12:07 PM
Default Sit down vs. stand up seating
Can someone explain what the difference is in hull design for sit down vs. stand up seating ?
Is it strictly seat to floor, dash and control placement or are other things involved ?
ed
Interceptor is offline
Old 11-17-2006, 02:47 PM
Codered's Avatar
Default Re: Sit down vs. stand up seating
I am not a boat builder or anything like that but I know that freeboard is a consideration on a stand up boat vs a sit down boat . I prefer a stand up boat wit alot of freeboard. Just my 2 cents
Codered is offline
Old 11-17-2006, 02:59 PM
THEJOKER's Avatar
I personally like to sit down. Out of the wind , connected. Always faster.
THEJOKER is offline
Old 11-17-2006, 03:01 PM
THEJOKER's Avatar
These are comfy.
THEJOKER is offline
Old 11-17-2006, 03:02 PM
Tricky919's Avatar
I want the option to do both..........
Tricky919 is offline
Old 11-17-2006, 03:14 PM
THEJOKER's Avatar
I laminate aluminum in the cockpit floor and through bolt / lag the seat frames in. Freeboard is not an issue as we custom set every seat frame to the customers specs. I have foot inserts in the dash so you can push like crazy. This does two things - 1. Keeps you planted in the seat 2. Takes the load off your spine / back. This directs pressure to your shoulders. This works well for us and hope this helps answer your questions.
THEJOKER is offline
Old 11-17-2006, 03:19 PM
onesickpantera's Avatar
It's not freeboard it's cockpit depth. Usually boats with more cockpit depth are stand up boats.
onesickpantera is offline
Old 11-17-2006, 03:34 PM
SeaRay Sundancer
tblrklakemo's Avatar
I am a tall guy....what are some V boat makers that have deep cockpits...that you guys have seen.
tblrklakemo is offline
Old 11-17-2006, 03:56 PM
Team Dysfunctional
Hot Boat's Avatar
I converted mine from stand up to sit down. I will never go back to standing again.
I did have use a large spacer on the helm to get the steering wheel closer to me and had to re position the throttles.
Attached Thumbnails Sit down vs. stand up seating-picture-019.1.jpg   Sit down vs. stand up seating-picture-018.1.jpg
If it aint broke .... I can break it....
Hot Boat is offline
Old 11-17-2006, 03:59 PM
JC Performance Engines
Stormrider's Avatar
Active Thunder.
Stormrider is offline
Quick Reply: Sit down vs. stand up seating
