-   -   Twin Turbo engines? (https://www.offshoreonly.com/forums/general-boating-discussion/145652-twin-turbo-engines.html)
FROGMAN524 11-21-2006 09:34 PM
Twin Turbo engines?
Does anybody know who makes the engines with the twin-turbo set up that Reggie Fountain ran in his 42' lightning at the Chicago Poker Run? Thanks.
jeff32 11-21-2006 09:50 PM
Re: Twin Turbo engines?
were they really turbo engines ? or Supercharged?
steve1k99 11-21-2006 11:26 PM
I know they ran motors built by this company in RioRose at the Washington race and at least on other race. The boat was fast as he!! but had mechanical issues. Im guessing these were the same motors they ran down in Jacksonville pokerrun.
http://cetengines.com/
burtandnancy 11-22-2006 12:18 AM
No, but one guy who is outstanding with EFI twin turbo engines used so often in west coast ski racing is GT Performance in Upland, CA
427eliminator 11-22-2006 12:45 AM
They ran stellings supercharged 1500's for the jacksonville run. The new motors were twin turbo 2200 hp with 2200 ft/lbs of torque. I do not remember the company name off hand. They featured the turbo motors on Powerboat Tv.
Paul
cougarman 11-22-2006 08:39 AM
Not sure if this is what your looking for but sounds very interesting .
Chief Engines / Apache with Turbo's
Cougarman
jhiguy377 11-22-2006 11:58 AM
Read the patent- refrigerating air charge/ combustion chamber temp. (adiabatic effect) may not be a new concept.... but this guy has put it into effect with dramatic results and the thermal efficiency is significantly improved. I've always thought it was a bit goofy to tone an engine way down to low compression (low thermal efficiency) then just ram a bunch of air and fuel back in to make horsepower.All you tech heads, what's the down side besides what mentioned in the patent (piston ring pressure)?
Cat man do 11-22-2006 12:42 PM
GT MARINE IN LA SEEN ONE AND IT LOOKED NASTY. CALL GARY :evilb:
fountain1fan 11-22-2006 03:45 PM
jhiguy377 you are 100% right , and steve ik that is the company that makes the motors in RR. :drink: i saw them at morehead nc and what jhi said is the reason thay make so munch power . robbie
flat rate 11-22-2006 04:21 PM
The Guy Building Those Motors Is Using Rio Roses As A R And D Boat And Paying The Bill To. It Not Really A Reggie Thing. When It Left Keywest It Was Going Back And Having The Sterlings Taken Out And Another Set Of These Motors Are Being Put In. If They Stay Together They Are Doing A Kilo Run In January.
