Centrifical Supercharger Sound ! >
Old 12-04-2006, 11:55 AM
  #31
littledcsrodshop's Avatar
Default Re: Centrifical Supercharger Sound !
Originally Posted by articfriends
I'm running a baja 272. The best it has ran is 92.8 mph gps,5800 rpm's,1.50 drive w/32 pitch 4 blade labbed prop,it will run 89 ish any day of the week w/4 people and 3/4 tk of gas. The video was of boat idling in driveway after installing a stellings box this past summer while checking for leaks,bleeding the steering lines out,etc. I usually run ggb mufflers,in the video they weren't back on yet. The sound from thje cockpit is much different,when idling it is like others described,there is a slight ringing noise from blower rattling the step up gears along with a steady slight whine. At wot throttle is sounds sorta like a turbine,Smitty
What drive are you running ? looks like a bravo ( I would assume an XR.) Any idea what your boat weighs ?
I assumed that I would get some whinning sound which is perfectly fine with me. I was mainly woundering how much cam chop it would cut out , which from the rear it doesn't sound like it cut too much out. Do you know the specs. on the cam you are running ? Have you ever had your engine on a dyno ? Sorry for all of the questions it just that it is winter & cold so it makes for good computor racing !!
littledcsrodshop is offline
Old 12-05-2006, 12:08 AM
  #32
articfriends's Avatar
Cam is hyd roller around 230/238 at.050 and .610 lift,RMbuilder spec'd it if you want exact numbers on a cam custom built for your motor he is very good. Motor made a little under 950 hp on tyler crocketts dyno at 5700 and a little over 950 ftlbs tq at 4700. Tq band was 800 plus ft lbs from 3500 past 5800. Outdrive is a bravo style with every upgrade part max marine worx sells plus recently a special gear treatment I been experimenting with on the lower gears. I repair my own drives and have a full out max worx drive for a spare too. Most their parts along proper,exacting clearences will help a bravo live for a while in a single v(mine is around 5500-6000 lbs w/fuel and passengers) with some pretty healthy power.The mufflers help my boat idle better and do not slow it down whatsoever,i just had them off in the video because we were in process of putting boat back together and they weren't on at the time,Smitty
articfriends is offline
Old 12-05-2006, 08:20 AM
  #33
Talking Re: Centrifical Supercharger Sound !
My M3SC sounds like two wild pigs f*cking!
kennyo is offline
Old 08-14-2013, 04:17 PM
  #34
vortech, resurrecting a 6 year old thread lol
http://www.youtube.com/watch?v=Sl-eY4bQDNA
launchpad475 is offline
Old 08-14-2013, 09:07 PM
  #35
I really like the Procharger F3R reverse rotation, with a custom made intercooler and 600 cubic inches.
Some of these cars make 50psi of boost
http://www.youtube.com/watch?v=FfkBG...C1495C&index=6
Pro1 is offline
Old 08-15-2013, 11:12 AM
  #36
mgh
http://www.youtube.com/watch?v=aHsenC6TkAU
HP500, Aluminum Heads, M1 w/ intercooler, 3psi
mgh is offline
Old 08-15-2013, 11:42 AM
  #37
Man, look at all that room around the engine to work!
Wasted Income is offline
bichaum
31
02-08-2008 05:26 PM
Bryan Rose
5
11-14-2006 03:28 PM
JJONES
8
06-29-2005 06:32 PM
dropthehammer
8
02-19-2004 12:18 AM
rocksolid
5
02-26-2002 05:08 PM
Quick Reply: Centrifical Supercharger Sound !
