Like Tree0Likes
Oh Oh ..... What did I do now?
Old 12-23-2006, 06:43 PM
BAD KITTY
rickdarling's Avatar
My Boats: 28 Warlock SXT, 33 Tiara Open
Default Re: Oh Oh ..... What did I do now?
Sorry to hear about your troubles. It really sucks first time out after motor work.
Pretty windy a few miles south of you. I'm surprised you didn't get any.
rickdarling is offline
Old 12-23-2006, 06:52 PM
StillHaulin@63's Avatar
My Boats: 2000 Baja 232 Boss
Weather was A+ at Marina del Rey.
Sunny at 65* with 1' wind waves (not even) and maybe a 2-3' swell about 15 seconds (seemed like miles) apart. I was actually going to push WOT in the open sea!
FYI
The engine is a 454 Mag MPI with 150 hours
(Only 1 hour since the valve job and tune up)
Oil Pressure stayed at normal!
40+PSI at idle (700rpm) and up to 45-50psi at 1500rpm
limping home.
Was about 60psi when I noticed the problem.
StillHaulin@63 is offline
Old 12-23-2006, 06:59 PM
ReggieRaft's Avatar
My Boats: 35 Lighting
Bring it back . Waranty 100% .
ReggieRaft is offline
Trade Score: (1)
GO4BROKE's Avatar
My Boats: Sonic 386
Sounds like valvetrain to me.
[img][/img]
GO4BROKE is offline
Old 12-23-2006, 07:06 PM
Thanks so much for your input everyone.
I do plan to take it back to the mechanic next week.
It is so helpful to at least have a pretty good idea of whats wrong when I take it in.
Not being mechanical, I get BS'd quite often.
BTW
Merry Chismas & Happy New Year to all at OSO
Old 12-24-2006, 01:34 AM
Expensive Date's Avatar
My Boats: 05 35 Fountain EX
Sound like top end most likely a rocker arm don't think think its lower end you would have lost oil pressure.Could also have a lifter that bleed down.I am hopeing that the one of the keepers did not come out of one of the valves though good luck
Expensive Date is offline
Old 12-24-2006, 02:18 AM
Reed Jensen's Avatar
Did the mechanic resemble this guy?......
Reed Jensen is offline
Old 12-24-2006, 01:28 PM
SeaRay Sundancer
tblrklakemo's Avatar
My Boats: In the Slow Lane
Sounds like you have yourself a diesel.
tblrklakemo is offline
Old 12-24-2006, 01:41 PM
MM1
My Boats: 35 FT FOUNTAIN LIGHTNING
You probably have a broken lifter or a flat cam lobe because your engine dosen't use lock nuts to adjust thin e rocker arms they are bolted down into position and the machine shop that repaired the heads should have set the valve height and it won't be adjustable once the engine is assembled. I own a boat repair shop in socal and if you have any questions feel free to call Mobile Marine Service ask for Matt at 714 369 7410 and good luck.
MM1 is offline
Old 12-24-2006, 02:47 PM
Coleman's Avatar
My Boats: 26 American offshore
Loose Rocker pull the covers.
Coleman is offline
