Bezel Question: Sony Round Remote
1 Attachment(s)
Who sells the bezels that go under the Round Sony Remote pictured here? THANKS!
Re: Bezel Question: Sony Round Remote
Got mine from Livorsi. One thing you will have to do is to make a spacer that fits tightly inside the bezel, and drill 3 holes for the remote, 2 screw holes, 1cable hole. This will keep the remote centered in the bezel. Anything will work such as 1/8" plastic.
3 1/8 bezel 4" OD I'm pretty sure. I can double check mine as the boat is sitting in my garage if you really need to know. I do know the bezel is not the standard size. http://www.livorsi.com/catalog/powde...tm#FLAT_BEZELS |
Brian,
WWW.danamarineproducts.com makes exactly what you are looking for: http://www.danamarineproducts.com/st...TOKEN=11822794 |
Thanks US1. Your post came up on a search, and your custom ring looks REALLY nice.
Thanks for the link Bill. I was on DMP for a while, and could not find it. |
Well chit Brian, why didn't you just ask? :p and Thanks.
The Dana ones don't look to match the rest of the dash gauges profile. But it shows the hole pattern I mentioned. Either way a huge improvement over the w/o look. Whoops, just loooked at your dash pic up close. Looks to be a good match. |
2 Attachment(s)
My depth finder has the bezel replaced, and I am going to order the bezel for the tattle tale as well. It should all look nice together.
Maybe speaker covers next; or painting the existing ones. Trouble is I through-bolted them for anti-theft. I've got one next to the throttles now, and these are going in soon: |
Are your shifters purple or blue? (Looks blue on my PC, but so does my bezels, which are purple)
They are Purple.
Don't get too attached to that remote , it's gone and the new one is much bigger.
Originally Posted by Sydwayz
They are Purple.
I bought this from Trick this spring, but never installed it. I ended up making one that had a little different profile. Are you going to buy one or go w/o? I'll make ya a deal. :cool: |
| All times are GMT -5. The time now is 07:09 AM. |
