-   -   Paint Remmoval (https://www.offshoreonly.com/forums/general-boating-discussion/149807-paint-remmoval.html)
Sick Stinger 01-22-2007 10:18 PM
Paint Remmoval
Looking to remove paint from my swim platform. Its a bar styleplatfor like seen on a powerplay or as in my case a Thoroughbred. I want to repaint it because of the chipping and peeling of it. I beleive its stainless if im correct
Griff 01-23-2007 12:29 PM
Re: Paint Remmoval
Its aluminum and the best way to refinish it is to have it sand blasted and powdercoated.
Sick Stinger 01-23-2007 09:11 PM
Re: Paint Remmoval
Hey griff i just took it off and took some paint off it is SS but i would assume the same physics and system would apply to cleaning and painting am i correct??
SUNSATION 25 01-23-2007 09:20 PM
Re: Paint Remmoval
I paint, and you are correct! if it's a peeling problem then it needs to be blasted! but if it's just chips from use then it can be featheredged and painted over with no problem............
Sick Stinger 01-25-2007 05:16 PM
Re: Paint Remmoval
no it need to be taken down to bare steel then re shot do i have to power coat or can i prime and paint
BY U BOY 01-25-2007 05:32 PM
Re: Paint Remmoval
have it powder coated it will look much better and last longer.
cuda 01-25-2007 06:08 PM
Re: Paint Remmoval
I have to disagree. When the pc starts to chip, and it will, it comes off in big flakes.
SUNSATION 25 01-25-2007 06:24 PM
Re: Paint Remmoval
If it's a peeling (adhesion) problem then it needs to be stripped, if it's just chips from use it can be featheredged and primed then refinished. And I agree with Cuda, have it painted rather than powdercoated..........
Monza SS 24 01-25-2007 09:08 PM
Re: Paint Remmoval
I used paint stripper from lowes and had mine powdercoated again. The stripper made it easy to get off.
Sick Stinger 01-25-2007 09:41 PM
Re: Paint Remmoval
The chips are huge nothing that a blend or feather edge will help i have a bady guy that does all custome stuff (if anyone need it also) to take care of it i just have to prep it but i want to be part of the project so that we can do a little customeizing with paint=-)
