Best way's to remove paint graphics???
is there other ways to remove paint from a boat to get it back to white gel coat other than sanding. I know it can be painted white, but at a big cost, is there a chemical, high pressure procedure, sand blasting or easy sanding method to remove it, thanks
Re: Best way's to remove paint graphics???
Oven off (easy off)
if you are very sure its gel coat under paint , paint stripper will work then just buff the sides to bring out the gel shine ,but be damed sure its gel under the paint
Ovenoff only works on uncatalized paint i.e. painted pinstripes, lettering etc........also any of the liquid strippers that will remove paint have a very good chance that it will damage the gel underneath!!! if you want to do it the right way the first time, sand it off and repaint it white!!!!
and I do paint for a living so it's not secondhand knowledge............. |
There is a product called klean strip just for that. Wont hurt the gel.
Originally Posted by jryan26
(Post 2013219)
i used to build boats [24'-40' offshore]and owned a bodyshop too,dads paint works great [from wal-mart] if your careful and like i said if its white gel coat under it, it beats sanding
Razor Blade The Stripes Off The Gel Then Sand And Buff It To New. It Sounds Scary But It Works.
Originally Posted by flat rate
(Post 2013426)
tried the clean strip, very strong, don't get it on you, helped loosen paint, still took quite a bit of sanding, would take forever to do entire boat, anybody have anything else to try.
Originally Posted by Steve_H
(Post 2013463)
done it that was also. round the corners with a file so they dont dig in.
Great tip on rounding the edges.:cool: |
1 Attachment(s)
Here's the best way......GO VINYL!:drink: :drink:
| All times are GMT -5. The time now is 07:28 PM. |
