All aluminum 1100 cubic inch V8 >
Old 02-07-2007, 01:30 AM
Rob
Strip Poker 388's Avatar
Default All aluminum 1100 cubic inch V8
I found what stecz20 needs
A friend of mine that works for MSD sent these picks to me,figured you'd get a kick out of them , Just think put a pair of these in a boat with some big props. Looks like a monster of a motor,ck out the TQ I think he would win the ooooh ahhhhh factor
Just thought I'd share some before and after pictures of my Ford GAA tank engine. All aluminum 1100 cubic inch V8 used in WWII Sherman Tanks. These were gas burners rated at 500 HP and 1050 Ft. Lbs. of torque for military service, but are capable of much much more using mostly stock parts. They feature a 60 degree vee, 5.4 bore x 6.0 stroke, 180 degree factory billet cranks, pent roof combustion chambers, shaft driven DOHC's, 4 valves per cylinder, and dual mags. They are pretty high tech. engines, especially considering they were built in the early 40's. I've been working on getting one of mine going for the last couple of years, and should be cranking it within a week or so. It's setting in my 70 Mustang right now which I plan on taking on short cruises when finished, 24 gallons of alcohol wont go very far. It is bolted to a heavily modified Powerglide right now. Wilcap ( Pat McGuire ) built the adapter and flexplate for me.
Attached Thumbnails All aluminum 1100 cubic inch V8-cid_006301c74a87%2481a12310%246501a8c0%40c2de6300.jpg   All aluminum 1100 cubic inch V8-cid_006501c74a87%2481a12310%246501a8c0%40c2de6300.jpg   All aluminum 1100 cubic inch V8-cid_006701c74a87%2481a12310%246501a8c0%40c2de6300.jpg
Strip Poker 388 is offline
Old 02-07-2007, 01:31 AM
Rob
Default Re: All aluminum 1100 cubic inch V8
Ci it out sticking thru the hood, just think if it had a big blower on it
Attached Thumbnails All aluminum 1100 cubic inch V8-cid_006901c74a87%2481a12310%246501a8c0%40c2de6300.jpg
Old 02-07-2007, 01:34 AM
Semper Fi's Avatar
Interesting......but probably weighs more than the Titanics anchor
Semper Fi is offline
Old 02-07-2007, 01:37 AM
tomtbone1993's Avatar
i like it
tomtbone1993 is offline
Old 02-07-2007, 07:51 AM
Charter Member #927
Payton's Avatar
Put 1 of those in a 32-35' boat. That IMCO splitter with 2 drives on the back.
Lighter and lower center of gravity than 2 small blocks with the power and torque of 2 big blocks. Assuming you could build it to about 900hp
Payton is offline
Old 02-07-2007, 07:55 AM
Forum Regulator
Sydwayz's Avatar
Received 1,185 Likes on 515 Posts
33 AVH Super-Single Thunder has a nice ring to it.
(There is already 28 AT that will be going into independent development with a big single and Arneson Surface drive later this spring.)
Sydwayz is offline
Old 02-07-2007, 08:03 AM
Registered User
Why not use Merlins?
P.S. I'll bet that trailer is WAY faster than that Mustang!
Chris Sunkin is offline
Old 02-07-2007, 11:12 AM
Nice pic's
Dd24skater is offline
Old 02-07-2007, 12:24 PM
I cannot believe there isn't a propellor guard in front of that Merlin engine!!! Start that baby up- Yikes
wannabe is offline
Old 02-07-2007, 12:45 PM
weren't they using them in ult hydors'? (hence the term thunder boats) before they switched to turbines??
phragle is offline
Quick Reply: All aluminum 1100 cubic inch V8
