twin 283 gm big blocks
Lakeside Restorations.com
Commercial Member
283's are small blocks You should probably also do a good tune up, oil change & a carb rebuild may be needed.. Jamie / lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
SeaRay Sundancer
The old 283 Chris motor has solid lifters,, if it has set for 8yrs it might have the rings froze to the pistons ,,, I had to pour some of my Vodka and Orange juice down the Carb so there was enough compression to light off the Starting fluid ,, that was after 2 starters were burned up,,,, dont try to re-wire that thing ,,, it is installed backwards ,,, wow ,, what great memeories that thing was,,,, after it fired we ran it for about 1hr and the rings loosened up and it was a very good motor ,,,, have fun !!!
RHC
RHC
RHC
RHC
Try these sites for a lot of info and a good resource for parts too:
http://www.network54.com/Forum/424840/
http://groups.yahoo.com/group/cccommander/
I know this works on Pontiac engines, and I think it will work on Chevy's, too. Take the handle off a blade screwdriver, and put the driver in your drill chuck. Take out the distributor, and put the blade down the hole until it contacts the oil pump shaft. Turn on the drill motor, and build up some oil pressure for about a minute. Now your bearings are primed with oil, so they won't start up dry. I would also put some oil in the cylinders, too, as others have mentioned.
Michael
Michael
