2 motors, 1 V-drive help
Working on this boat …. very long story and I don’t want to taint anyone’s thoughts before they answer by going into it.
It has 2 motors that go to one V drive then to one prop. One motor sits in front of the V drive and one in back of it. Both motors have transmissions and don’t worry about motor rotation or anything else but the question. So here goes.
How would you connect the two motors to the V drive?
A,
B,
A,
B,
Pic A. Do you have the original V-drive? I assume that you don't. Depending on the drive you use, you would need to rig a straight thru shaft on the top. Basically just add another flange on the opposite side of the case. (easier said than done) The transmissions should allow you to engage / disengage each engine separately, so I think it could be a solid coupling.
Are you going to use crash boxes or standard trannys? How would regular transmissions react to differences in RPM? I would think trying to sync both engines through a borg or similar could create a lot of heat. Crash boxes would effectively lock both engines together when in gear.
I know your boat has a very unique setup, and I can only imagine trying to dock a single with two crash boxes to deal with!
Does any of this make sense???
Have the original Casale 1000 (only about 40 made), 1.09 to 1. A B/W Velvet drive, 1 to 1 on each motor.
As I said I don't want to get into all the logistics until I get a consensus on how folks would do it if it was theirs. I will be more then very happy to discuss it all then.
