Originally Posted by ReggieRaft
(Post 2070174)
You know somebody is going to pull up next to you to see who is faster. Then what do you do? Hit it.
then after only 10 hrs its hammer time with no worries cause thats why you have a warranty. |
Originally Posted by MacGyver
(Post 2070124)
But if you do have an issue, Merc could pull the engine statists from the computer and tell you..."Sorry, the warranty is void because you ran past 3/4 throttle"
Correct me if I am wrong here. I know the computer tracks what rpm's the motor has run at. (I was amazed to find out just how much time I have spent in no wake zones.) But I don't think it tells you WHEN those rpms were logged.
I can understand 3/4 throttle for the first 2-3 hours......after that! Run it like you normally would if it had 100 hrs on it.
We just built brand new engines and sent them to the dyno....he ran them to near 6,000 rpms and they were just put together!!! |
Originally Posted by Macklin
(Post 2070343)
(Post 2070124)
Please ignore all the uninformed people who say to just run the engine at full throttle from minute one. They have an extremely small sample size to base their opinions on. I don't know of any "major" engine manufacturer who recommends this, nor do they durability test their own engines without a break-in period. Michael |
Then how about the issue of Dyno testing. All major engine builders dyno their engines immediately after assembly. Run them hard after minutes of break-in.
Kinda more of a question than a reply, but do the ECU's on the 496's (or any other high performance EFI Mercury) not have a break-in mode like the outboards do?
I know on a new 280, the ECU runs in a break-in mode until it has determined the motor has been "broken in" |
Originally Posted by DORaymond
(Post 2071404)
I had a guy whos ecu tracked that 1/2 of the engines short life was pegged at the rev limiters. :eek: :eek:
| All times are GMT -5. The time now is 11:13 AM. |
