-   -   Does water get trapped in step hulls? (https://www.offshoreonly.com/forums/general-boating-discussion/154597-does-water-get-trapped-step-hulls.html)
BL6 03-27-2007 05:17 PM
Having owned all straight (non-step) hulls, looking at step hulls. As water gets in the bildge from time to time and shifts around while underway, can it move forward and get trapped in to step portion of the hull? Can this cause any problems? I realize various manufactors have different types of steps, some have drain plugs some do not.
Also some boats I've owned bildge is always dry, on others water seeps in and I have pull the drain plug at ramp each time. Is water in bildge a threat to hull?
thnks!
dave911 03-27-2007 05:37 PM
From what I've seen steps would not impede water from the bow toward the transom. Should not be a problem.
**EDIT...I'M WRONG ON THIS...READ OTHER RESPONSES**
Water is xxtra weight, and will likely find and exploit any imperfections in a boats finish, which will ultimately corrode something and lead to early hull / stringer failure.
Basically,
Water outside boat = good :D
Water inside boat = bad:(
bouyhunter 03-27-2007 05:42 PM
Good question to post.
I've owned three boats, and grew up on two of my father's.
All five boats were kept in the water, and there was always at least a little water in the bilge. Probably rain.
I've run on other guys boats that were strictly trailered, and when we pulled the boat out, there has always been some water in the bilge.
Maybe overspray from wave crushing, maybe otherwise, I don't know.
Donzi38ZXXX 03-27-2007 07:05 PM
I have separate bilge pumps in the step areas.
Sydwayz 03-27-2007 07:52 PM
AVH Active Thunders come with an automatic water sensing bilge pump at the base of the step. As an option at build time, you can have drain plugs installed in the aft portion of the step.
mmwalters 03-27-2007 09:51 PM
I know in a cat the answer is yes
2112 03-28-2007 12:31 AM
So how do you get it out on boats where they are not accessible?
Tip the nose down low and vacuum it out up front?
bobkatz 03-28-2007 07:02 AM
We pull the plugs on the ramp, and tow it home with them out. The new boat has two little bilge pumps in the front steps to get any trapped water out.
Airpacker 03-28-2007 07:04 AM
That is exactly what I do with my daytona. Good old shop vac.
