Exhaust tips needed
Anyone have four tips laying around? I need the style with the rubber flange and straight pipe, so I can angle them a bit. Thanks, MT
1 Attachment(s)
Would these work? We have four.
How do you attach those tips to a rubber exhaust hose? I never saw those before?
Originally Posted by MILD THUNDER
(Post 2122254)
Originally Posted by Lucky Strike Jr
(Post 2122269)
They bolt on to the transom. You have to run the exhaust hose through the transom to the tips. Do you want tailpipes or exhaust tips? These are exhaust tips.
(Post 2122279)
The only kind I ever saw were the standard bolt on tips that the tip goes into the bilge and you connect the hose and clamp to the tip inside the bilge, and the kind that have the flange/pipe separate with the rubber flange gasket. So with your tips, the rubber hose goes thru the transom hole, and then clamps to the pipe? Im sorry man, I dont get it??
Are you still in need of tips?
yes, still looking
I have four used straight back tips with rubber flappers and internal shutters - 4". Excellent condition - $225 shipped.
