-   -   Are Tie-bar's needed? (https://www.offshoreonly.com/forums/general-boating-discussion/157892-tie-bars-needed.html)
tomlesli 05-09-2007 09:58 PM
I am buying upgrades for my Alpha Drives. I plan to buy drive showers. I have noticed that in a lot of pictures on this web site boats have tie-bars. What is the purpose of tie-bars?....are they necessary or more cosmetic?
phragle 05-09-2007 10:00 PM
they take a lot of the stress off the tiller and post, pretty easy to make if you can tig, yook me about 2 hours to make mine.
tomlesli 05-09-2007 10:52 PM
I only have a mig welder, I do not have anything to weld aluminum or stainless. So in your opinion they are needed? By the time I buy the joints, material in stainless, and someone to weld them--I should probably pay CP's price.
phragle 05-09-2007 10:58 PM
they will save your stuff, so I guess there needed.
phragle 05-09-2007 11:04 PM
http://cgi.ebay.com/ebaymotors/NEW-T...QQcmdZViewItem
just a little cheaper..this guy has several...
hunster 05-10-2007 06:25 AM
I had a loose gimbal on the port side and bought it to take up some of the slop in the drive origionaly. Since I have changed the transom. I do still run it , Eddie marine makes a nice one and it allows for more mis-alignment in the drives than others like the latham heim joint style. Looks like the imco is similar.
Reckless32 05-10-2007 10:44 AM
They're also integral to your drive toe in/out adjustment.
handfulz28 05-10-2007 11:30 AM
Is there a "standard" tie-bar measurement for say non-staggered BBC/Bravo setups?
pullmytrigger 05-10-2007 12:15 PM
tie bar, drive showers and regular drive oil changes are best things you can do for any alpha set up......some guys put on the Merc remote oil resovior set up on too
hunster 05-10-2007 12:39 PM
When I ordered mine , I had to give the center to center prop shaft measurement. There is adjustment , but it needs to be near the measurement and you can adjust the toe out from there.
