BAZOOKA Tube ?
Does any one have any experience with using a Bazooka Tube sub woofer in their boat? Any pro's or con's? Do they sound pretty good or not? This is the one I am considering. The black automotive ones are a little cheaper. I suspect the white which is stated marine may have very minimal differences. I am thinking it would fit perfectly in one of my side storage areas where I store fenders now. Thanks for the advice!
Bazooka MBTA10200 Marine Certified 10" High-Power Amplified Bass Tube Product Description: Marine Certified 10" High-Power Amplified Bass Tube Patented Bass Tubes enclosure design Water resistant enclosure Weather resistant velcro reinforced mounting straps Salt fog and UV certified for 5 years White paint finish Gold plated 5-way binding posts Power Handling: 200 watts Sensitivity: 104 dB Frequency Response: 39 Hz - 250 Hz Magnet Size: 28 oz. Dimensions: 21.1"L x 10.3"W x 12.2"H 1-year Sonic Electronix warranty Subwoofer Specifications: Subwoofer Size: 10" Impedance: 4 ohms Dual Voice Coil: N/A Peak Power Handling: 400 watts RMS Power Handling: 200 watts Woofer Surround: N/A Woofer Composition: N/A Sealed Box Volume: N/A Ported Box Volume: N/A Sensitivity: 104 dB Frequency Response: 39 Hz - 250 Hz Xmax (millimeters): N/A Top Mount Depth: N/A Cutout Diameter: N/A Warranty: 1-year Sonic Electronix |
2 Attachment(s)
I used the Black Bazookas tubes on mine and they sound much bettter then I thought they would with good thump!
I couldn't bring myself to cutting any holes for subs so I went the tube route and am very happy with the results. No issues being non-marine after 2 seasons! |
If you want hard rap type thump at very loud volumes look elsewhere. Bazookas work quite well for some really decent bass.
Recommended! |
put four of em in and pump the thump
just make sure you keep a screwdriver handy to tighten all the screws that are gonna loosen up,,,,,,,,,, |
if there crossed over correctly and some good juice is pumped to them they will hit hard
Thanks for the feedback.
ZP'd - It looks like you went with the Bazooka Tube with out the integrated Amp. Any one with a recommendation with or with out amp? I'm thinking of getting one with the 200 watt built in amp. Then will use a JL Audio 4x75w amp to power 4 Alpine 6.5 speakers. Nothing crazy just want clean sound with some bass. |
If I where buying I'd get the external amp, more control and if you want to up grade you can use it for something else also the marine isn't worth the extra $$ unless you want white
http://www.etailelectronics.com/Merc...ore_Code=etail I did 2 8" subs in mine in the same type of location as you want to use and it sounds great just make sure you give them enough clean power, I would of done 10's if I had it to do over so now Im trying to find a place for these 12"s I have laying around I would go with truck style boxes and 2 10" inch subs boxes bottom depth is less than the tube http://www.crutchfield.com/S-sximaF6...0&I=044T6510SS 10s http://www.crutchfield.com/S-sximaF6...FFSize%7C10%22 I recommend these and JL I have both and they are worth the money these are the 8's I have they are the Mclass http://www.memphiscaraudio.com/ |
I have the 10" amplified marine Bazooka tube and it hits decent. I was actually expecting a bit more though, but that could be because I had 2 15" subs in my truck in high school.
I wanted the ability to have a bit more control, thus the 8ohm tubes bridged off the Alpine 220 amp.
The only goal of my system I had was to be able to hear it well at speed with a little thump and they more then do that. |
My shop is factory direct with Bazooka and we stock many models of Bazooka tubes. Call Mike or I when you are ready to order and we will get you a deal.
Maximum Audio Tampa,FL 813-882-8477 |
