-   -   Question For The Chesapeake Bunch (https://www.offshoreonly.com/forums/general-boating-discussion/158274-question-chesapeake-bunch.html)
cig1988 05-15-2007 05:57 AM
Planning a road trip to the south in a few weeks with the boat. At over a combined weight of 18,000 lbs there's little room for mistakes. I plan on leaving the Island around 2am which will put me in DE by rush hour. I was looking at route 301 @ DE which will dump me on the north side of Richmond. Been well over 15 years since I've been on 301 driving semi's. What should one expect that time of the day and has 301 improved over the years ? I do remember traffic lights/stop signs on 301 but was alot quicker taking that way to avoid DC and Baltimore traffic at times.
Any suggestions ?
offshoredrillin 05-15-2007 06:08 AM
Any suggestions ?
301 will bring you all the way to 97 and 695, it is much more scenic but lots of lights, still better than the mixing bowl (imo) toll at the HW Nice bridge other than that a straight shot. You'll see the exit right past Kings Dominion...did you sell the 20 Harry?
Shore Thing 05-15-2007 07:28 AM
301 is in much better condition than it used to be. However, it also has much more traffic now.
Ted G 05-15-2007 07:52 AM
You may run into trouble at the Bay Bridge also, you are coming across with all the commuters. (DO NOT get stuck in the left lane as you approach the bridge-they may force you onto the eastbound span and 2 way traffic) Once past there it is just lights, etc. until you get past Waldorf, then it opens up some.
Sydwayz 05-15-2007 08:45 AM
I-95 does often suck, but it is bearable.
I'd adjust your timing to come through the Baltimore/DC area at 9PM-4AM or 10AM-2PM.
103.5 FM is your friend for DC traffic every ten minutes on the 8s. They normally refer to both DC and Baltimore Beltways as their respective Inner Loop and Outer Loop, so make sure you have that down.
Also, Sirius has as DC/Baltimore traffic station that alternates reports every 4 minutes.
I've traveled 301 several times towing from Richmond to the Annapolis area. There are no real issues with the road, but it does switch from 2 to 4 lanes, and back to 2 lanes a bunch of times. There is a lot of truck traffic, especially toward Richmond as there are a lot of quarries off of 301. It looks like a straight shot, but it takes me 3.5 hours to tow from Richmond to Annapolis.
45sonic 05-15-2007 08:50 AM
Used to drive that route all the time bringing boats to the Eastern shore. 301 is a nice detour from 95N. However, you will run into a lot of lights after crossing the 301 bridge (toll only from MD to VA). The mileage is just about the same as if you came through Springfield. The exit for 301 off 95 is 104 ( a huge truck stop refueling stations everywhere)
I personally like to be on the move so I prefer the Springfield route better ( no stop and go unless you hit it around rush hour)
Aggressor 25 05-15-2007 09:23 AM
"107.7 FM is your friend for DC traffic every ten minutes on the 8s."
WTOP 107.7 has changed dial position to 103.5 FM. See what happens Brian, you move to Richmond and lose all touch with the great traffic we have in NoVA :mad:
Sydwayz 05-15-2007 09:40 AM
Thanks Ty! I actually knew it switched, but forgot about it when posting. I fixed my original post.
http://www.wtop.com/?sid=590400&nid=6
http://www.traffic.com/Washington-DC...c-Reports.html
http://www.usastar.com/i95/homepage.htm
http://www.nbc4.com/traffic/index.html
All of the above links have traffic links for I-95.
OldSchool 05-15-2007 12:23 PM
I hate to admit it, but...:stupid:
It'll take longer and you have to drive right through a few towns (like Waldorf and LaPlata) that are the Nation's Capitol for inbreeding.
:drink: :evilb: :drink: :evilb:
offshoredrillin 05-15-2007 01:21 PM
lol, well you know the only road through oxen hole leads nowhere :D
cig1988 05-16-2007 03:42 AM
It may be too early in the am for me but when you say the Springfield route is that I-95 ?
offshoredrillin 05-16-2007 06:01 AM
yes, they call it the mixing bowl, its where 95 meets 495 (capital beltway)Last year I was there and lots of construction. I dont know what it's like now.sorry
45sonic 05-16-2007 06:07 AM
Thanks Rob for the clarification sorry about that. The new ramps taking you to the inner and outer loops are much improved over the ones that were there. Construction is ongoing but usually with few or no lanes closed. Much better than it was before.
cig1988 05-17-2007 03:36 AM
I may just plan on leaving after rush hour from the sand bar here. Orignally wanted some sort of day light to keep my eye on things.
