removing decals from fiberglass
Just bought a used boat that has 2 little decals on it that need to be removed. Are there any techniques you can share?
Thanks. |
blow dryer.... heat it up... and peel away
Hair dryer or a heat gun.
Originally Posted by dreamer
(Post 2128877)
Originally Posted by lucky strike
(Post 2128881)
Your quick bro !
(Post 2128903)
might be down monday...
I was going topost a similar question. I did the heat gun thing and got the decals off but it left a residue. GooGone doesn't work in removing the residue....any suggestions?
acetone and then wash and wax
3M makes an eraser you put on a drill. Forgot the technical name of it. That is what you need.
Originally Posted by Playn
(Post 2129242)
WD40 takes off the sticker residue... this is what Formula recommends for their boats, when you take off the shrink wrap tape.
Another of those 101 uses for WD40. Gotta luv that stuff.
Originally Posted by cig1988
(Post 2129259)
Took about 100 feet of 1" stripe off with it. Worked great. |
Originally Posted by Griff
(Post 2129244)
Use the eraser wheel randy. It works like a champ
(Post 2129259)
Thanks all. I'll give the WD40 a shot first and see if that does it.
(Post 2130182)
Originally Posted by nashpda
(Post 2129884)
Just used an eraser from 3M on my decals. Removed all the decals and glue reisdue in about 20 minutes
