496ho Redline....
Does anyone know what the Mercury 496HO redline is? If anyone knows it would be a big help, because I've heard three different answers...5000RPM....5100RPM, and I've heard that the rev limiter comes on at 5150RPM?
Thanks |
Max rpm should be 5000. The rev limiter kicks in at 5150 rpm.
John:D |
Yup, I run mine to 5000.
book says range is 4600-5000, but I'm pretty sure 5150 is the tev limiter, seems I've read Teague commenting that the sweet spot is to prop them for 4900, pretty good torque curve for a mild engine- about to try and pull some 34" 5 blades this week, 32's are over 5k now:)
I think the rev limiter is actually 5250 but I may have that confused with another engine. It's at least 5150 cause seen that before with different props.
Usually Mercury makes the rev limiters 150 rpm above max rpm.
John |
rev limit at 5150, prop it right at 5000
| All times are GMT -5. The time now is 03:04 PM. |
