tv install 25baja
tv install 25baja
trying to install a tv in a 25 outlaw. what is the best way to do this? i dont have shore power. i want the tv to be removable for when running. i have the tv and the wall mount. i will also be hooking up to sattilite tv. what ideas you guys have?
Im intrested in this also.Like do you find a 12v tv?Do you go with anything and use a inverter? What kind of bracket/or fix mount?Thanks for anyones and everyone help and input.
I am also thinking of putting 2 20" lcd's in my Outlaw. I was just going to use a power inverter on mine, but I am also concerned about the screens when the boat is coming back to earth..... Maybe a rubber mounting system???
Registered User
have a 17" lcd in mine mounted permanently no problems with banging around , we have a dvd player also but no shore power in boat . we only use it when tied up at the marina so i use a regular heavy gauge cord with an adapter to the shore power outlet and have a power stip that we plug everything into mounted under the galley cabinet
I also have been thinking about an lcd tv in my 357. I have searched the threads for any info. I want a 12 volt tv but dont want to pay $500 for a 15" tv. It seems some people have had luck hard wiring 12 volt tvs into there boats and some people cant get them to work. From what I can tell from the postings the 12 volt tv needs only 3 volts to run any more and the tv will not work . As we all know are boats run on a 12 volt system. The tvs also would like a regulating power supply. I think I my have found the answer.
http://www.powerstream.com/dc6.htm
