How can I beat my bro's boat?
You know,the sbling rivalry deal.Here's what we have.My brother has a 1997 Baja Hammer 21 footer with a 385hp 454mag totally stock.
I have a 1997 Scarab 23 SCS with a 415hp 502mag mpi totally stock except the IMCO exhaust. I out weigh him by about four or 500 hundred pounds.The hole shot we're bow to bow but he starts to pull away once on plane. I would like to stay away from procharging as that's not in the check book this year.What would be some reasonable bolt on HP increase so I can waste his boat? Sorry to offend any BAJA OSO'ers but his race car,snowmobile,atv and boat is faster than mine. |
what rpm are you turning at WOT? Depending on how much he's pulling on you, you may be able to make up some ground with a different or worked prop............That may be your cheapest option. Or get a fat friend to ride with your bro....
I went to a 26p Bravo1 4 blade on mine and still do every bit of the original advertised 76+ MPH and the boat does a much better hole shot.
pull out the interior.
as soon as he starts pulling on you, rub rail his a#$ throw a roll of hefty bags in front of his boat spray it or try a better prop and exhaust. that should free up some power and give ya maybe 3 or 4 |
Stuff potatoes in his exhaust....
Originally Posted by monstaaa
(Post 2142449)
remove his:evilb: drain plug= you win............
Man....... This sibling chit is serious!!!!!!:evilb: :D
sugar in his gas tank will work for sure!:evilb: Seriously, you should be able to take him. I think your set-up needs tweaking!
