Outdrive Oil
Outdrive Oil
I have a 496 HO running on a Bravo 1 drive. This is my first year with the boat and I lost a good bit of outdrive oil. The oil was changed in the fall. then when I took it out for a good days run I came back on the waring alarm was going off. I had lost enought fluid to go down past the sensor in the resivor. Leaving maybe a quarter inch in the fluid tank. Is this comon after changing the fluid ? maybe an air buble or somthin ? Or should I be concerned there is a bigger problem here ?
SORE MEMBER
I used to encounter that problem on occasion, now, when filling the drive, I re-install the top plug and continue filling from the bottom of the drive until I see a minimum level in the reservoir, at that point I stop and top up to the full line. This seems to eliminate any air pockets.
Have someone watch the reservoir, as it is easy to overfill the bottle using this method.
Nice idea. I will do it this way from now on.
OSO Moderator
This is normal. Takes an outing or 2 to get all the oil back at the top.
Refill to the top line and you'll be fine - unless you start seeing oil in the bilge. Then you DO have a problem.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
Ok - boat out of the water and on the trailer. It turns out the oil is leaking some where on the bottom and getting into the bildge. The bottle is all clean and in good shape the hose as far as I raech to trace it is clean as well.
How dificult is it to get to the connection at the bottom where the resivor hose goes into the outdrive. Can it be done by pulling the outdrive or am I looking at having to pull the whole motor for a stinking loose hose ?
SORE MEMBER
You should be able to follow the hose down to where it goes through the transom assembly, if you cant get your finger on it, tie some q-tips to a coat hanger and see if that is the leak, if not then it's probably the carrier assembly seal seal on the outdrive input shaft. You would have to pull the drive to see that. If it's leaking bad it fills the bellows and seeps back through the bearing
Last edited by Wobble; 06-04-2007 at 12:26 PM. Reason: corrected my terminology :)
I would say its leaking pretty good. A 20 minet ride to get the boat back to the launh and pull it out the whole reserve bottle was empy again,
Can it come threw the u joints ? I read a past pot here and that was what other though about a simular issue.
Also any good mechanic shops in CNY - Cicero are with a quick turn around time ??
SORE MEMBER
If it's still bright green oil in the bilge, it may be the hose/bottle leaking, if it's somewhat dirty oil then it has come through the bellows most likely IMO
