-   -   oil coolers..... (https://www.offshoreonly.com/forums/general-boating-discussion/160609-oil-coolers.html)
baja250es 06-11-2007 08:32 PM
oil coolers.....
i have just finishe buildin a 54o bbc, could anyone tell me if an oil cooler is needed an why? thanx
pkspx 06-11-2007 09:45 PM
I'm not an engine builder but, I think bigger the engine you would most certainly want a oil cooler. PM Mrhrosepower1. He can give you awesome pricing, he has a few.
US1 Fountain 06-11-2007 09:45 PM
Motors in boats don't get the air flow around the oil pan to cool the oil as in cars and trucks.
You'll need one, or start on the replacement motor. :)
t500hps 06-11-2007 09:51 PM
I just built a 540 out of 502's and one of the oil coolers is not circulating. At 3,200 RPM's the oil gets to 215 degrees in less than 10 minutes. Over 4,500 for 45 seconds and it passes 250 degrees. Ran it this weekend at 2,700 and it stayed around 205 so I would idle every 20 minutes to let it cool back down. After just 3 hours running the oil looks like chit already!!!
You NEED an oil cooler, and a BIG one!!!
fastedy 06-12-2007 05:34 AM
1 Attachment(s)
I have a big one with power sterring cooler by revolution, make offer, $269 origonal cost
Eddie
Richmond VA
kennyo 06-12-2007 07:36 AM
Eddie
Richmond VA
This is what you need at a minimum. Put a temp gauge on it also, in the pan if possible.
