-   -   Engine Heat (https://www.offshoreonly.com/forums/general-boating-discussion/161063-engine-heat.html)
perform330 06-16-2007 10:27 AM
Engine Heat
Has anyone had this problem?
The boat runs good everything is fine, then after running the boat for about 1 to two hours the port engine gets hot. Shut it down and wait until its cold run it again same thing.
Help
BY U BOY 06-16-2007 10:57 AM
Raw water pump needs to be checked,or its time for a new water pump if you have one.
Edward R. Cozzi 06-16-2007 11:10 AM
Need more info.
What year and model engine?
FWC or RWC?
Last time raw water impellers changed?
