keikaffer drive gauge adjustments ?
my drive gauges when drives are all the way down read port side "0" starboard "3" how can I get them even ? already tried adjustments from drive units made a little difference . is there an adjustment under the dash ?
yes they can be adjusted under the dash or with the panel removed - but - using another person, to watch the panel, disconnect the indicator cable at the drive and move it manually to see what is going on; you may have to relocate the mounting bracket on the ram itself as the threaded portion of the cable may not be adequate to recalibrate your "zero" position. good luck - jeff
| All times are GMT -5. The time now is 04:27 AM. |
