Gas or diesel generator
What are the pro's and con's between the two. We do over night, and have always had diesel, but are worried about the Carbon Minoxide. Have the gas gotten better. Thanks Jeff
Jeff, the new kohlers are very safe, stay with the same fuel source as the boat engines, the exhaust discharge on the nortech's are under the transom . would still have sensors in both cabin and engine compartment . I believe kohler has an auto shutoff c02 sensor available, like the overheat/oil low shutoff sensor. Sold my 50v so I'm looking at going back to a cat, still love the nortech 36, maybe the new extended roadster model. jim
I've got a Westerbeke 3 KW. It's gas and only weighs 165 lbs.
I think the builder is required to install a carbon monoxide detector with a gas generator. |
I owned for 6 years a sea ray 380ss and used the gas gen more than the engines. it was a 8kw westerbeke and never gave me a problem. Just changed the oil twice a year and kept on enjoying the air conditioning up at havasu
Originally Posted by DonziJapan
(Post 2347992)
Dont mix your engine room. Gasoline engines are built to coast guard spec. To prevent ignition of gasoline vapors. Diesels are not. Put a diesel genset in a gasoline boat or a gasoline genset in a diesel boat the boat go BOOM!!!:eek:
I ended up putting a diesel Mase genset in my gas boat, just like my last 5 boats...and im still around.:D |
Originally Posted by Jassman
(Post 2348015)
Originally Posted by docmanrich37
(Post 2348025)
But thats only because Sandy says your worth more alive.:D
Hey baby, aint that the truth, see ya in a few days:D Sandy |
(Post 2348342)
The facts are the facts. A hazard exists thats why the Coast Guard has all the extra safety regulations for gasoline engines but not for diesels. The odds are 5 to 1 in your favor playing Russian Roulet but I bet you ain't taking a little spin at the cylinders any time soon. :evilb:
(Post 2190705)
Originally Posted by Wobble
(Post 2348487)
Carbon Monoxide (CO gas) issue will be the same whether you go gas or diesel. As mentioned elsewhere, redundant CO detectors are the way to go.
What does having two types of fuels, in seperate tanks, in totally different locations on your boat make it more combustable, especially when diesel is not combustable...someone explain that to me. Thanks Jeff |
| All times are GMT -5. The time now is 07:41 AM. |
