-   -   380k-planes (https://www.offshoreonly.com/forums/general-boating-discussion/164109-380k-planes.html)
375stinger 07-22-2007 09:03 AM
380k-planes
I tried posting this in the tech area. I am in need of two 380k-planes (just the actual "plane" or tab), to modify existing 280s to the 380 length. I need the style to fit a 1990 tab. Does anyone on the board have leftover tabs of the older style? Or where could I find a set of used ones to repaint if needed? We need them asap, if anyone knows any leads, etc. it would be very appreciated. Thanks
Sydwayz 07-22-2007 09:04 AM
380 Plates only are extremely hard to come by. I have only seen two sets come up for sale in my 6 years on OSO, and I bought one of them.
open87 07-22-2007 09:58 AM
HERE'S 1 IN THE SWAP SHOP.....
http://www.offshoreonly.com/classifi...ct=3293&cat=32
bcschoe 07-22-2007 10:20 AM
You can use the new 380 plates. Order new plates, new lower pins, the busihings, and washers.
Call Brownie at Stainless Marine and order a new end piece for the trim indicator cable attachment.
Remove the trim hydralic cylinder and cut each side equally with clearance to fit inside the tabs.
Verify clearance on the inside edge of the tab to verify your drives will not hit the tabs at ny setting.
375stinger 07-22-2007 10:24 AM
Open: Thanks, i just contacted the guy with the tab, but ill still need another one to run...lol
BC: Thanks, do you know of where I could purchase the tabs and parts required to do the switch? Thanks
bcschoe 07-22-2007 12:07 PM
Any Mercury dealer. Like Tres Martin Performance!
375stinger 07-22-2007 01:06 PM
Thanks! Just sent him a pm..
