Like Tree0Likes
Big cubic inches or supercharger?
Old 07-27-2007, 01:17 PM
  #31
StraightJacket's Avatar
My Boats: 38 Fountain Fever with #4's, ok so it really 35
N/A's from this camp .. 540 std deck 730 hp 690 ft lbs of torque, put together right very dependable .
StraightJacket is offline
  #32
My Boats: 24 Skater, 292 SR-1 Formula, 382 Fastech, 41 PC
the 622ci motors were from 1800runsnew.com
Anyone have any experience with them? What else will be needed for a swap if they are "fully dressed"? If i purchased these, are they an easy swap or is this something thats would need to be custom.
waterboy222 is offline
Old 07-27-2007, 03:26 PM
  #33
My Boats: 39' Sea Ray, 38' Nortech, 18' Taylor SJ
Make sure you can get fuel to them.
Tall deck motors possible have an exhaust issue due to deck height. Most of the time not though.
Also check new overall height because f new intake, different carb etc.
That will get you started. THe rest you will just have to figure out.
jeff1000man is offline
Old 07-27-2007, 04:03 PM
  #34
Rob
Trade Score: (6)
Strip Poker 388's Avatar
My Boats: Hustler 388
Superchargers
Strip Poker 388 is offline
Old 07-27-2007, 04:29 PM
  #35
My Boats: 1999 270S Hallett
I like my 540 built for a 700-1000 hp. All the good lower end stuff, steel heads(salt water), small whipple(side mount 2.3). dyno'n this weekend. should be around 800 +. throw on a larger whipple say 3.3 or a set of whipples and have to do NOTHING to the engine. then you have over 1000 hp. its all about the long block. OVER build the long block = HUGE OIL COOLER and put whatever you want on the top. Oh by the way, its fuel injected..
I'll post more info if anyone want it on a 502 build up. will be a 540 SIDE MOUNTED WHIPPLE. I don't think you'll see many of those around. This set up is for us guys who don't have a deep engine well and don't have a scoop.. going to look sweet....
VegasHallett is offline
Old 07-27-2007, 04:35 PM
  #36
Wardey's Avatar
My Boats: 2005 Extreme 29
Carolina Racing Engines did my 572's cu in but I only have Tyler do my motors now. Link is on my signature at the bottom. Dave
Wardey is offline
Old 07-29-2007, 09:46 AM
  #37
My Boats: Big Ole 42' Cruiser w Arnies.
Wardey - fellow Floridian here - Tyler who?
Swamplizard is offline
Old 07-29-2007, 10:03 AM
  #38
Geronimo36
Panther's Avatar
My Boats: 36' Apache Warrior / 22' Apache Scout
Quote:
Originally Posted by Gary864 View Post
I have had blowersin a 32 Sunsation that was tough to beat but I have a long idle in and out of my canal and the blowers seemed to load up. This might be fixed with fuel injection but I am no expert.
sounds like a setup issue...
I'm running 580" blower motors (838 hp - low boost) and have no idle issues what so ever. If it was loading up it probably wasn't set up right.
Panther is offline
Old 07-29-2007, 01:10 PM
  #39
Wardey's Avatar
Quote:
Tyler Crockett with Tyler Crockett Racing Engines. One of the best in the business and very trustworthy. Link is at the bottom. Dave
Wardey is offline
Old 07-29-2007, 02:54 PM
  #40
Running to rich down low, but probably need it high.
A freind of mine has same problem. Rotate one in and out of neutral and keep the Rpm's up to clear them out.
bcfountain
Fountain
9
08-14-2007 03:17 PM
SinkorSwim
28
12-11-2003 12:38 PM
Ratchet
11-16-2002 05:20 PM
