MSD box questions and problems???? >
Old 07-26-2007, 05:48 PM
kaama82's Avatar
Default MSD box questions and problems????
Anybody out there with MSD box problems, or am I the only one. Not running anything exotic. 6m2, seem to lose one every 2 to 3 seasons. Anybody with the same problems???
kaama82 is offline
Old 07-26-2007, 06:47 PM
KNOT-RIGHT's Avatar
Make sure your big red wire has got a good connection to
B+.
Same with the ground.
When you loose one do you send it back to MSD
for diag??
KNOT-RIGHT is offline
Old 07-26-2007, 06:50 PM
I lose one 6m box every year.
skater40 is offline
Old 07-26-2007, 06:52 PM
SORE MEMBER
Wobble's Avatar
I lost a couple over about 6 years then started using their surge supressor at the recommendation of their tech guy, stops the spike from the starter motor from harming the ignition, no further problems yet. I cant think of the part number.
Wobble is offline
Old 07-26-2007, 06:54 PM
Toxic FORMULA
mopower's Avatar
I still haven't figured you why people use them. I want reliability on the water.
mopower is offline
Old 07-26-2007, 07:42 PM
Crane
brian41 is offline
Old 07-26-2007, 07:53 PM
Geronimo36
Panther's Avatar
One new box 3 years ago and one original, no problems yet.. knock wood.....
Panther is offline
Old 07-26-2007, 08:28 PM
kaama82's Avatar
I have not sent them back because they said they are NOT repairable.... I did find out that they will warranty them for a full 3 years. MSD also said the same thing, It was a spike that damages them, not neccessary right then, but hurts them enough that they will fail in the very near future...
kaama82 is offline
Old 07-26-2007, 08:50 PM
Havn't had problems except when they are hooked to starter lead.
Make sure each engine is on its own dedicated circuit.
I use the Hot off of the original merc. ignition.
Good luck with the next set.
jeff1000man is offline
Old 07-26-2007, 08:57 PM
Six years and never a problem on 6als.
AO31 is offline
Quick Reply: MSD box questions and problems????
