-   -   New big block, what prop to use??? (https://www.offshoreonly.com/forums/general-boating-discussion/165320-new-big-block-what-prop-use.html)
Nate Sears 08-04-2007 03:35 PM
I just purchased my first big block, and was wondering what prop to use for the best performance. The boat is a 23' Mirage with the 454 Magnum and the Bravo outdrive. What prop will give me the best performance, and what kind of rpm's should I expect? Thanks for any help you can lend!
Griff 08-04-2007 07:57 PM
Best top end prop will probably be a Mirage Plus. Most likely a 23". You want to prop it so the engine turns 5000rpms with that engine.
jeffbare 08-05-2007 11:59 AM
What gear ratio is the Bravo? Is it a 1.5/1?
Nate Sears 08-06-2007 08:17 AM
I'll cehck the gear ratio, and start looking for a Mirage Plus, thanks!
