Like Tree0Likes
Being Cheated at the Gas Pumps?
Old 08-09-2007, 09:40 PM
S.O.B (single O/B) now
t500hps's Avatar
Quote:
Originally Posted by White Knuckles View Post
That is for E85 (85% ethanol) which is hard to find. E10 (10% ethanol) is dam near everywhere. I have to travel outside the "metro" region to where E10 was not required.
t500hps is offline
Old 08-09-2007, 09:41 PM
t500hps's Avatar
Quote:
Originally Posted by pachanga View Post
.......................... I will gladly pay up to 30c per gallon more for gas now if I know there is no ethanol in it!
Ethanol free gas actually cost LESS!!!!! It just costs me a few gallons of diesel to get the boat there to fill up.
t500hps is offline
Old 08-09-2007, 10:02 PM
My Boats: 2000 28 PANTERA
All I Know Is It Seems To Burn Quicker Than Normal Guess Id Better Slow Down A Little
Baddogg is offline
Old 08-09-2007, 11:31 PM
My Boats: Formula
Your problems aren't just going to be the reduction in fuel economy. Ethanol entraps water and moisture, and that is going to cause a lot of problems with equipment that doesn't see constant usage (like boats, especially ones with large tanks). It also can cause problems with older motors i.e outboards and chainsaws that were mfg. using rubber compounds in their diaphrams and fuel lines not compatible with ethanol.
Make damn sure to drain out ALL of the fuel from your small-engine seasonal equipment. Even though we are paying more for it, the shelf life of gas is a lot less- 2 months or so if not treated, especially since they took the MTBE out of it. I have found PRI-G to be very good (a lot better than Sta-Bil, and can give back that some of that lost economy). OMC fuel additive, now Bombardier is quite good too, and I know several that swear by SeaFoam. I don't buy gasoline anymore for anything without treating it when I pump it.
With the coming of ULSD, you better be adding Stanadyne, DieselKleen, or PRI-D to that diesel tank too or your injectors are going to suffer due to the loss of lubricity in the fuel.
For those of you lucky enough, the Jet A going in your Falcon, Gulfsteam or Lear (or turbine Skater) is still as it used to be; good old Jet A
jafo is offline
Old 08-10-2007, 12:20 AM
Charter Member #232
Audiofn's Avatar
My Boats: 1979 Formula 302, 99 Formula 353, 81 Donzi 18 2+3 with 454
Guy I work with has a BMW and went to a gas station and the Ethenol concentration was so high in the gas that he got that it messed up his fuel system. Cost him like a grand to fix!!!
Put your best foot forward!
Audiofn is offline
Old 08-10-2007, 08:16 AM
CigDaze's Avatar
My Boats: Cigarette 35 Cafe Racer
Quote:
Originally Posted by mccaffertee View Post
Ethanol doesn't burn cleaner than gasoline, nor is it cheaper.
Our current ethanol production represents only 3.5 percent of our gasoline consumption, yet it consumes Twenty (20%percent of the entire U.S. corn crop
It has caused the price of corn to double.
It is raising the threat of hunger in the Third World
Increasing acreage devoted to corn for ethanol means less land for other staple crops.
Farmers in South America now have incentive to carve fields out of tropical forests.
The price of beef, poultry and pork in the United States rose more than three percent during the first five months of this year.
And as a gasoline substitute, ethanol has bigger problems:
Its energy density is one-third less than gasoline, which means you have to burn more of it to get the same amount of power.
It also has a nasty tendency to absorb water, so it can't be transported in existing pipelines and must be distributed by truck or rail.
READ MORE, Interesting.
http://www.rollingstone.com/politics..._boondoggles/1
Bingo. Those are the facts.
CigDaze is offline
Old 08-10-2007, 12:43 PM
My Boats: Advantage 28ft Sport Cat w/ pair of 8's
Only one reason ethanol is being pushed in the US. The giant farm conglomerates have a huge pull in Washington. It is basically another form of subsidy. And like the previous post stated, the price of corn has doubled. Hhhhmmmmmm......
As a fuel it's junk.
Darrell.
DMOORE is offline
Old 08-10-2007, 01:01 PM
My Boats: 1987 2100 Galaxy, 502 Magnum
Be cautious Ethanol will eat away the inner layers of poly tanks and fuel lines. The material breaks apart and then gets pump through your fuel system. NMMA has been doing research since 2001 on the effects of Ethanol on marine devices. Would be a good idea to check into it.
Skeed UP is offline
Old 08-10-2007, 03:02 PM
My Boats: 2002 Baja 25 Outlaw
87 Octane is $2.89 a gallon here...and that's a HUGE drop from 3 weeks ago! We're actually relieved to be payin that "little". Go figure. How effective would a COAL burning offshore boat be?
Freeryd is offline
Old 08-10-2007, 04:01 PM
My Boats: 1987 Donzi 22; 2008 Donzi 28 ZXO
I agree with your post, except it is a bit too one sided.
The line above is correct, but well stated to make you think it is terrible fuel...
Fact is, ethanol should make more horsepower than gas. Yes, you have to burn more, but it still produces more power. It doesn't help our cars much because they are geared for the lesser of the 2 power curves (even flex fuel vehicles). If they were geared for the best mileage burning E85/E10/etc. though, would it be more comparable to gas? It should be, but I have yet to see a study that takes that approach.
Just food for thought
VetteLT193 is offline
JBoat
07-01-2008 06:42 PM
wrasse
07-06-2007 09:34 AM
yzbert
04-29-2004 11:07 PM
Byron
04-04-2003 08:44 AM
