Hydraulic steering leak Imco
Has anyone ever had their Imco cap leak that takes the place of the original power steering cap. I have a 31 Sonic with 496ho's and the original reseviour is leaking from the replacement Imco cap. I know there is an O ring there. When you release the cap it acts like its under pressure, which seems normal. If I release the cap will I loose alot of hydraulic oil or is there a way to relieve the pressure. If so where do you bleed the air after making the repair?
Thanks in advance for any help
