7.4I magnum
Can anyone tell me the difference between the 7.4 and 7.4I magnum? Would the 7.4I magnum be enough to power a 32 Envision? I'm looking at this boat hard, but don't want to get it if it is underpowered from the get go.
thanx |
Originally Posted by bert4332
(Post 2239595)
thanx Assuming that they are EFI engines, the 7.4 is 330 HP, at a max RPM of 4600. The 454 Mag is 385 HP at a max RPM of 5000. The 454 Mag has all the good forged parts in it, while the 7.4 was not really intended to be a high performance engine. |
Like Duke said, the 454MAG is a much better package. Especially if you plan on any performance upgrades.
Darrell. |
Either way, if its a single in a 32 Envision, its way underpowered. That boat needs twins.
Depends on what yr the motor is.... if its a mark IV mid to late 80's then MERC labeled 330 hp oval port head 454's with the MAGNUM cuz it was pushin an alpha I 1.32 ratio.
A non mag 454 can be built for performance use. Your building all your HP at a relatively low RPM. 4800 to 5500. No problem for a pro built BBC. Would be nice if it did have the big rods, forged crank and forged pistions BUT Rectangular Port heads are not any better building torque/hp at boating RPM's I would look at how well the boat was maintained. HP is like Hamburger.. You can buy as much as you want. good luck with the purchase :cool-smiley-011: |
1 Attachment(s)
The boat is a 1995 Envision Intruder combo, see attached pic of motor.
As it says its a 454 mag and 385hp. Still way underpowered for a 32' boat. It would probably run 50mph on its best day.
Is there a formula to use to establish how much more HP an engine will need to get me to a certain speed? Mid 60s is where I want to be.
(Post 2241797)
I've been looking for the formula for that insurance brokers use. I used to find easily and now I'm drawing a blank on how I searched for last time.
| All times are GMT -5. The time now is 07:50 AM. |
