-   -   Towing cap. h1 hummer (https://www.offshoreonly.com/forums/general-boating-discussion/169665-towing-cap-h1-hummer.html)
Velocity Tom 09-25-2007 08:50 PM
Will it pull 10000 pounds?
cbeastwood 09-25-2007 09:05 PM
'06 Alpha has 300 Hp / 520 ft. lbs. Towing capacity is 9,500.
Earlier years' towing capacity was about 7,500.
520 ft. lbs. is not a lot for a 10k load.
Don't know if I'd install a chip - don't know how strong the Allison 1000 tranny is...
flat rate 09-25-2007 09:57 PM
?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????:Whatever ::Whatever::Whatever::Whatever::Whatever:
PhantomChaos 09-25-2007 10:41 PM
Originally Posted by flat rate (Post 2284904)
???????????????????:Whatever::Whatever::Whatever:: Whatever::Whatever:
http://www.seriouswheels.com/cars/to...r-H1-Alpha.htm
cbeastwood 09-26-2007 06:38 AM
Flat Rate,
What part of my post didn't you understand? If you have a problem with what I wrote, please let me know.
haulinvols 09-26-2007 07:31 AM
Short answer is No. According to the Hummer site, the H1 Alpha is only rated at 9300 pounds in the soft top version and 9050 in the hard top version.
Mercury_Challenger 09-26-2007 08:36 AM
As long as you aren't going cross country and staying some-what local you might be OK. Remember, its not always in the HP and torque, its also the handling and stop side of it to factor in, if you do choose to tow it, keep a safe distance from others at hi-way speeds and check into some good fluid for that tranny, possibly even another larger tranny fluid cooler would help also.
haulinvols 09-26-2007 09:27 AM
Here we go again, someone get the popcorn. :food-smiley-007:
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
