-   -   Winterizing in climate controlled buildings (https://www.offshoreonly.com/forums/general-boating-discussion/170191-winterizing-climate-controlled-buildings.html)
dukenrock 10-02-2007 08:18 PM
I've seen alot of posts regarding winterizing for freezing conditions. Is there a standard guideline for "winterizing" for a temperature controlled building where we don't have to worry about freezing?
GO4BROKE 10-02-2007 08:23 PM
I'd still add antifreeze for the corrosion protection, and in case the furnace fails.
Griff 10-02-2007 08:52 PM
My garage has the furnace/heater set at 40* in the winter. I have not used antifreeze for the last 3 winters. RV antifreeze does not offer any anti corrsion properties anyway. I just add stabil to the fuel and do normal season ending maintanance. Also, I don't have to worry about condensation in the fuel tank, because temp changes happen slowly.
Elite Marine 10-02-2007 09:34 PM
Better to invest in the glycol, just in case!!
baywatch 10-02-2007 09:40 PM
I am envious of Griff. I need to get myself a climate controlled building!!
dukenrock 10-02-2007 09:42 PM
That's all I do but usually set the furnace a bit higher.. I had to add a dehumidifier to the building so I can maintain the humidity as well. (Not so much important in the winter months)
BOBCATMATHEWS 10-02-2007 09:45 PM
all it takes is a huge snow/icestorm no power for a couple days,i would prep it like it was outside in alaska,can't hurt and the cost isn't that much different. my .02 cents.
jafo 10-02-2007 09:52 PM
About the same, except I keep my shop quite a bit warmer since I work in there thoughout the winter months. One NG heater is forced air, one is infrared that requires no power, and the floor is heated so I'm not worried about an outage. I drain the blocks and hoses, but don't use anti-freeze. I perform normal end-of season oil/lube changes on engines and drives. I used to use Stabil many years ago but have found Pri-G to be a much better storage additive for the fuel (I have used SeaFoam a time or two with success as well).
MOBILEMERCMAN 10-02-2007 10:38 PM
Extended storage. You should prepare your boat to sit whether its indoors or out. Protect the fuel system. Protect cooling system and external surfaces from corrosion. It's best to drain and replace with an anti freeze like propylene glycol. To drain and leave dry is worse then leaving water in it as far as corrosion goes. For what little it costs it's foolish not to do the best you can with it. Sure you can get away with less, but why?
Jim
RedDog382 10-03-2007 06:36 AM
Kevin,
Even though I keep my building @ 50* all winter, I still winterize with automotive antifreeze. Never know when there might be an extended power outage. Not worth the risk of cracking an engine block.
boss252 10-03-2007 07:38 AM
I have always kept my boat in a heated garage but I winterize it as if it will be stored outside. Why take the chance. Remember Murphy's Law. If anything can go wrong, it will.
cigrocket 10-03-2007 08:07 AM
Winterize, so it doesn't keep you up at night. The fact is that the question came up, so you already had doubt. Extra few bucks to fill with antifreeze. Less then a bar tab
Chris Sunkin 10-03-2007 08:11 AM
I use RV antifreeze- it's way less sloppy to clean up.
I did the emergency winterize one night (all night) on two boats and two jetskis. Not much fun.
Queenie 10-03-2007 08:13 AM
Ditto!!! We have heated storage and always winterize with antifreeze and stabilizer.
Panther 10-03-2007 08:16 AM
Jim
I agree with Jim! Besides everything else it also provides internal engine protection to fog the motors.... I fog my lawn mower in the winter and snowblower in the summer...:rolleyes:
In addition to that, if I'm working on a boat with a big lift cam and high seat pressure I also go thru and loosen up the rocker arms so all the valves are closed over the winter... The belief is the springs retain a memory from being compressed for a long period of time.... It may be overkill but only do it on big HP engines with big cams.:cool:
