-   -   I Surrender! Time to Re-rig (https://www.offshoreonly.com/forums/general-boating-discussion/170839-i-surrender-time-re-rig.html)
320es 10-10-2007 09:51 PM
The envision is a straight hull.
tblrklakemo 10-10-2007 09:55 PM
Isnt there some prop work that can cure your problems...or have you been there done that?
Frequency 10-10-2007 09:56 PM
Originally Posted by BenPerfected (Post 2302291)
... I spent $25-50K the figure this out...probably a lot more but this is all I will admit to :D
Our typical outing on the water involves two to three couples and their kids. It will be this way for the next 3-5 years. I could have easily put the same amount of cash I've spent into a mid 90's cafe or gun with good power and solid drives. It's just not the right time for me. So I'll make this thing work the best I can. I will miss the Pulsedrive for sure. The swim platform at the waterline. Running and docking in two foot of water (not two foot on the depth finder - two foot from the surface). A sweet rooster tail that you could just sit and stare at. But a 70 mph boat with a cool rooster tail is still a 70 mph boat. Can I run 90mph? Probably...but I won't like what Sir Issac does to me if I have a failure at that speed.
Frequency 10-10-2007 10:01 PM
Yes, I've been there. The props are about 3 1/2 ft back from the transom. The best trim angle I can get and still be efficient is around 5 degrees negative. They will always push up. Round ears, cup and rake angle just can't overcome that fulcrum on the transom.
Frequency 10-10-2007 10:11 PM
Originally Posted by Von Bongo (Post 2302296)
I know one with a single 1250 in it, I hear it runs about a buck.
Over a buck ten according to our friends in Kaiser. ;)
thunderusone 10-11-2007 08:43 AM
Greg, I wish you the best.....lord knows you deserve a break! I wish I had some input that would work. From my own experience with my setup.....which is also in unchartered territory.....everyone else's ideas get very expensive! I know you know that all to well also. The prop change to the merc props was huge from the pulse props when I rode in it. I did not know that BBlades changed them to round ears.....what did that do? It floats great at midnight out of gas!! Eddie ran it out of gas on purpose so he could make a pass at me. Anyway, at least you can come up this winter and hang out at my shop and tell lies while Eddie is doing the perversion. We can knock back some diet Sun Drop.
Knot 4 Me 10-11-2007 09:07 AM
I wish I could have seen you running on the water at Clinton as opposed to sitting on the trailer. I love the rooster tail!!
Frequency 10-11-2007 01:07 PM
Originally Posted by Knot 4 Me (Post 2302609)
... I love the rooster tail!!
Ya, me too. I keep reminding myself of all the little things the rerig will fix. Better exhaust routing, clean up wiring and hoses, etc. Moving the engines back a foot will really help the boats CG too. In this hull, the benefits outweigh the advantages of the Pulsedrive. In a different hull, I'd keep it.
Smitty 10-11-2007 01:26 PM
Just break out a few more thousand (BOAT) and hang some 6's off the back and you will still have the roost!!!!
MacGyver 10-11-2007 06:34 PM
Forgive my ignorance, but what is a pulsedrive? It sounds nasty!
