World's First Innercooled Turbo Diesel Outboard Announced!
Sorry can't tell you this info at this time. All I can tell you is that the 2.3L has the same performance as a 225Hp 4 stroke and the 3.0L should have the same performace as a 300Hp 4 Stroke.
Gear ratio is 1.75. And the RPM is 3750 at rated power.
Hope this helps
Don
Geronimo36
PRESS RELEASE
October 25, 2007
Maritime Engineering Group, Inc of Ft Myers Beach, FL is proud to introduce the world’s first Turbo Charge Innercooled Diesel Outboard Engine. The new M.E.G. Vision Turbo Diesel will be available in 2.3L and 3.0L versions. Both outboard engines are common rail, electronic fuel injected, Tier 2 compliant and run on pump diesel fuel. The fuel rating on the 2.3L is 6 gallons per hour at wide open throttle. The engines are inline 4 cylinder with 16 valve direct acting double overhead cam. (DOHC). The outboards are electric, turn key start, with electronic throttle and shift. The shaft lengths are 20, 25, or 30 inches, and a counter rotating version will also be available. The charging system is fully regulated belt driven 50 amp. Exhaust is routed through the propeller and the cooling is by water with thermostat and pressure control. The lubrication is integrated dry sump and the oil capacity is 8 quarts. The weight of the outboards is 723 lbs.
Maritime Engineering Group, Inc is comprised of highly driven individuals with experience in the marine industry and a vision of making major improvements in the marine industry for the consumer as well as the dealer and boat manufacturer. For more information on the new M.E.G. Vision Diesel Outboard visit our website at www.megoutboard.com
October 25, 2007
Do you guys plan to build the company or sell the technology to one of the big boys???
This is the reason I missed all the fun runs last year. This year we will make them! Anytime you want to make the drive up to fort myers let me know we will go for a ride.
Don
