1969 Cigarette 28
My name is Phil Zisakis, I am sort of new. I have spent a little time looking for a project and ended up with the Cig discussed in this thread: http://www.offshoreonly.com/forums/s...d.php?t=168568
I removed all the carpet and glue from the floor and pulled the fuel tanks out. I have pressure tested them and was getting ready to reinstall. I was considering adding 1/2" fuel pickups and leaving the existing 3/8" for future return lines. I did a little research on the sight and it seems like I will be fine just leaving the 3/8" pickups. It has mild twin small blocks, later I will put in some hotter small blocks, maybe injected, but never big blocks. Anybody starving thier fuelpump with 3/8" pickups running small blocks under 700HP? Your thoughts on the subject would be appreciated. Phil Zisakis |
If you have them out and are going to put bigger motors in later it never hurts to increase your pick-up tubes diameter.
