Fogging EFI Motors, anyone mess up sensors? >
Old 11-07-2007, 01:13 AM
Default Fogging EFI Motors, anyone mess up sensors?
Reading up on fogging my 496HO motor, I've read those who say just to spray fogging oil directly into the throttle body and some who say that's crazy because it'll mess up the sensors.
The mechanic that just winterized my boat just sprayed fogging oil into the throttle body to fog it saying that's how he's always done it for EFI motors and there have been no issues.
So who's right? Any real bad fogging experiences?
wrasse is offline
Old 11-07-2007, 06:36 AM
Pwrbt33's Avatar
We have never sprayed fog into a dry intake, just wet intakes like carbed motors. Thats the way Mercury taught us to do it so thats the way its been done for years. Dry intake meaning anything with fuel injectors in the intake runners, wet meaning anything with a throttle body or carb. Everybody does it different so I cant say if he'swrong or right. You'll get hundreds of different responces on whats right or wrong.Good luck.
Pwrbt33 is offline
Old 11-07-2007, 06:38 AM
Macklin's Avatar
My mechanic said and did the same thing with my HO's. No issues over the years except I did have an IAC valve go bad. Who knows if it was related. It was the middle of summer when that happened.
But, I will be going with 2 cycle oil in the separator for my 525's.
Macklin is offline
Old 11-07-2007, 07:13 AM
CIG3's Avatar
I've heard of guys putting ATF in the fuel filter and running the engine to winterize. Not sure if this is ideal either.
CIG3 is offline
Old 11-07-2007, 09:53 AM
Brad Zastrow's Avatar
I have always been told not to spray a dry EFI throttle body. You are leaving an oil film on the sensors and and throttle body. I have read that the correct method is pull the fuel seperator and drain off half and fill with two stroke oil and run the engine for a few minutes.
Brad Zastrow is offline
Old 11-07-2007, 11:30 AM
yesrej's Avatar
thats the way i was told to do it so thats the way i do did.
yesrej is offline
Old 11-07-2007, 11:43 AM
berns29scarab's Avatar
+1
berns29scarab is offline
Old 11-07-2007, 11:46 AM
Forum Regulator
Sydwayz's Avatar
Received 1,195 Likes on 519 Posts
John has been a mechanic/friend of mine for years, and his word/advice has never let me down.
Pull the fuel/water separator. Why half-ass it?
*Also, replace your fuel/water separator in the spring.*
Sydwayz is offline
Old 11-07-2007, 12:53 PM
Default This is what Mercury says...
According to the MerCruiser Operation and Maintenance Manual for MX 6.2 MPI's (fuel injected) they recommend mixing 5 gallons of fuel, 2 quarts of TC-W3 outboard oil, and 5 ounces of Fuel System Treatment (802875A1) together. I cut the recipe in half and mix in a 3 gallon fuel tank. Connect this tank to the fuel inlet and run at 1300 rpm for 5 minutes. 2-1/2 gallons of fuel is PLENTY to fog two engines.
I too have heard it is a no-no to fog thru the throttle body due to possible sensor damage(?)...
4mulafastech is offline
Old 11-09-2007, 10:35 AM
baja bailey's Avatar
My mechanic runs the efi motors on a mixture like 4mulafastech talks about, not sure it is the exact formula of things or not though. I have always heard no fogging efi thru throttlebody also?
baja bailey is offline
Craney
23
09-18-2008 06:03 PM
sommerfliesby
10-11-2006 01:28 PM
Pismo10
3
09-05-2006 06:40 AM
tuttleman2
2
10-05-2005 04:49 PM
kook
5
07-08-2002 12:46 PM
Quick Reply: Fogging EFI Motors, anyone mess up sensors?
