Switching from efi to carbs, which intakes should I use?
Well guys, I'm leaving my area of knowledge, and switching from efi to carbs. Which intake would best suit my needs? Here's the engine spec's 502, AFR 315's, 8.75-1 compression, crane 741 cam.
I really need something with brass inserts in the water passages, unless I go with closed cooling. But I'm not sure I'm going to bother with the closed cooling, I would rather just get an intake with brass. I will also need a 4150 base, going off of what the carb shop is reccomending.
I guess I better explain that I'm not switching to carbs because the efi is a pain in the azz or anything, It's simply a money issue. I'm building a twin to the motor in my Velocity and putting them both in the Powerplay. So buying 2 harnesses/computers, 1 more intake/throttle body/injectors, ect. it will be way more affordable to just switch both to carbs.
Thanks,
Frank
Thanks,
Frank
Oops! I thought I posted it there. LOL I'm loosing it I guess.
Could one of the moderators delete this thread please? I reposed in the tech section.
Thanks,
Frank
Thanks,
Frank
I would recommend the world products marine intakes,only one with brass inserts really work nice,I am wd with world and can get you a good deal.The world intakes combined with a holley hp950 carb works great,plenty of power,idle great and easy to work on.give me a call 410-956-5381 dave.
Merlin intakes would be the best for your situation. The kit from CP does not have brass inserts in the water jacket. Buy them online at summit racing.com part # wrl-063042
I have been running the dart intake for 12yrs on a 509 at 600hp plus. I run salt water only flush out after use thats all. one dart intake I had is in my buddys boat thats 12yrs and THE ONE i have now is 7yrs went with aftermarket heads so needed new intake
