-   -   33 Powerplay speeds with 600hp (https://www.offshoreonly.com/forums/general-boating-discussion/174654-33-powerplay-speeds-600hp.html)
ls1nova 12-04-2007 07:45 PM
Anyone have any experiance with this hull? I know this hull is not the fastest, but what kind of realistic speeds should I expect to see with a solid 600Hp per side in a 94 33 Powerplay sportdeck? Would my expectations be too high if I was thinking mid to high 80s?
Thanks,
Frank
mjw930 12-04-2007 07:53 PM
Thanks,
Frank
That doesn't sound like a problem. I helped rig a 33 Powerplay a few years ago with twin 502 / 600's and we ran 91 mph on GPS all day long.
ls1nova 12-04-2007 08:11 PM
Awsome! Do you remember what year that one was?
Thanks,
Frank
mjw930 12-04-2007 08:18 PM
I think it was a '96 but the bottom design through that period was the same so unless it was layed up with a different material any 33 from that era should be very similar.
Indy 12-04-2007 08:45 PM
JROMY has a 33' with the Merc 525s and he gets 87, all stock engines and props.
FeverMike 12-04-2007 10:46 PM
Scott Utah's F2 33 Powerplay with HP500's ran around 83mph. Another couple 100hp should put you at 90+ @ WOT. With today prop technology and if the bottom and drives are really good you should do a little better.
Semper Fi 12-04-2007 11:15 PM
I had a 1997 33' Powerplay race model (3 man bolster) with staggered HP 500's-- she ran around 84mph top speed with 3 blade Mirage's.
I think with 600's you should be in the high 80's- low 90's. I can tell you that it's a BADA$$ hull for sure!
Indy 12-05-2007 06:51 AM
I know this hull is not the fastest, Thanks,
Frank
Trust me, it's plenty fast when the water kicks up.
WesSmith 12-05-2007 07:24 AM
With stock HP500's my 33 ran 80.
ls1nova 12-05-2007 03:25 PM
Is there any speed difference between the taller post 95 hulls, vs the lower pre 95 hulls? I'm guessing the pre 95's weight less.
Thanks,
Frank
baja27 12-05-2007 03:28 PM
I would assume that the post 95 hulls would be a tad slower due to having more free board thus being a little heaver.
Panther 12-05-2007 03:29 PM
When I worked at the marina a guy had a 33' PP with 600-650HP 540's... boat ran like 91-93mph if I remember correctly. Pretty sure it was a late 90's hull, maybe even 2000 or so...
Steve 1 12-05-2007 06:59 PM
The new hull mold was done in 94 the newer boats should run slightly faster with the refaired bottom!
PPlay33 12-05-2007 07:59 PM
The boat should run 88-91 depending on boat setup. I've seen 78-82 on 500hp boats just with prop changes.
MDGperformance 12-05-2007 08:18 PM
On your low deck hull 500 pushed them around 80,600 should get you around 86-88 depends on set up,actual hull weight and bottom condition,boat loves bay water and really well built.
SUNSATION 25 12-05-2007 08:18 PM
Already doing the motors eh Frank? Sorry I haven't called you back! between working lots of O/T and working on the boat and family my free time has been very limmited to say the least....
Dropped my engines off last weekend, hoping for 625-650HP can't wait to get her back together and on the water..............Jason
XPRESS 33PP 12-06-2007 04:21 PM
Good luck to you guys. Look forward to seeing your #'s when there done.
I'd like to try a couple of 7-10 Ilmors and some Konrads if $ was no object. I wonder how they would work in a 33?
SUNSATION 25 12-08-2007 09:31 AM
Thanks....
mr_velocity 12-08-2007 09:38 AM
502cu in Express Marine Engines just a tad over 600. Mike had the boat when I got the chip and that was in 1996. Not exactly sure the year but the motors were already getting tired when we did the Key West poker run in '98. Motors went in 99. Absolutely awesome riding boat and a blast with that power.
Man time flies.
open87 12-08-2007 09:49 AM
contact billy at gno http://www.gnocyclery.com/locators.html
he had a 33 with precision 750's /# 3's. it got the packages delivered...
