Like Tree0Likes
burned 2 cylinders on the outboard today, I give up!!!
Old 12-10-2007, 09:10 AM
Specialized's Avatar
My Boats: Baja 38 Special
Rick,
Sorry to here about the problems and feel your pain. I should be back up for new years though and you are welcome to jump on with us. I often wonder myself whether the agrivation is worth it but you just get this sport in your blood and kind of like heroin its hard to kick.
BTW I think boat is actually spelled with two t's Break Out Another (Ten,Twenty,Thirty) Thousand
John
Specialized is offline
Old 12-10-2007, 10:15 AM
sorry to here about it. try billy up @ power plus 561-5887088
art
dollerparts is offline
Old 12-10-2007, 10:27 AM
Trade Score: (1)
rchevelle71's Avatar
My Boats: 1982 Pantera 24sport
Quote:
Originally Posted by Specialized View Post
Rick,
John
Thanks John,
I may take ya up on the seat. I am thinking of just slapping another powerhead on it, but with the holidays and stuff, I may not be tested, and up to running with the big boys by then. Should only be about two t's in this boatt, two thousand or so this time
Rick
rchevelle71 is offline
Old 12-10-2007, 10:29 AM
Trade Score: (1)
Quote:
art
Thanks for the name Art,
I may just get another running powerhead, and be up and running real quick, just gotta take a few days off, and convince myself to part with the $$$$.
Rick
Old 12-10-2007, 11:34 AM
Charter Member #232
Audiofn's Avatar
My Boats: 1979 Formula 302, 99 Formula 353, 81 Donzi 18 2+3 with 454
Did you punch a hole in the cylinder or just have alluminum come off the piston? I have had a LOT of luck getting the allum. off the cylinder walls when I melted down a few pistons. Acid and scotchbright pad. It takes time but does work well.
Put your best foot forward!
Audiofn is offline
Old 12-10-2007, 01:21 PM
TeamTaboo
TeamTaboo's Avatar
My Boats: Fountain/MTI
rick give me a call, mite be able to help. 324-0536
TeamTaboo is offline
Old 12-10-2007, 02:40 PM
My Boats: Powerplay Center Console
in reply to the 2 bottom burned cyl. i would almost bet you got water back up thru the exhaust.could happen by coming off plane hard ,motor mounting to low ,excess water in bilge ,large wave hitting back of motor ,excess wieght on back of boat .seen it alot in my area ,people gather on back of boat at island to party ,drink and swim and flood to bottom cyl. also had a boat go into water no bottom plug and when he realized it started it up to put it back on trailer and burned two bottom cyls.this is also common on bracketed boats because the motor is so far off the back of boat it goes deeper than normal
allstarmarine is offline
Old 12-10-2007, 03:08 PM
marinetrans's Avatar
My Boats: 1991 SUTPHEN 26
Quote:
Thats a good old school trick.We did that too,with the chrome bores.Taking a shot at it won't hurt.
marinetrans is offline
Old 12-10-2007, 03:24 PM
racer-x6's Avatar
My Boats: Mid Stream Marine
Quote:
Originally Posted by rchevelle71 View Post
Checked the carb, looked clean. Weird thing is its just the 2 bottom, they run on the same carb. Head gasket looked funny, and appeared to have water in the cylinders, but cant tell if the head gasket went out first or after???
Heres some pics, starboard side
Check the string gasket between the cyl. and the exhaust plate. Does the exhaust plate look clean where the exhaust comes out of the cyl. ? if the leak is on the exhaust side it will suck water in on the down stroke. It is unlikely the both head gaskets failed at the same time.
racer-x6 is offline
Old 12-10-2007, 07:26 PM
Trade Score: (1)
Quote:
Bill,
I'll call ya tomorrow.
Rick
scarab39
46
04-30-2006 03:10 AM
restabr
Prop Talk
22
11-29-2005 11:50 AM
cloudmaster_321
6
05-14-2005 09:41 PM
ActiveThunderTodd
Active Thunder
12
01-23-2004 07:03 PM
