-   -   Quad Outboard set up and Gear ratios (https://www.offshoreonly.com/forums/general-boating-discussion/175455-quad-outboard-set-up-gear-ratios.html)
Enforcer2 12-14-2007 05:47 PM
Spoken to several different riggers on this and I am getting two different answers on how to set up drive rotation on a quad outboard v bottom.
Most popular seems to be left -left (for port side) and right right (for starboard side).
(Better bow lift and more control at docks.)
Also most common gear ratios seem to be 1:75.1 but I have been noticing 1:62.1 on the Merc Speedmasters and Torque Masters.
What's the benefit of the 1:62.1 over the 1:75.1 I heard the later is faster.
and lastely............. I've set up bracket for 30" centers. Again I have been noticing a shift in rigging where 20"s are used for outside engines and 30" for centers.
Any advise would be greatly appreciated.
Thanks Tony
rbhudelson 12-14-2007 07:04 PM
2 Attachment(s)
not exactly the same but here are two different ways of doing it on a Cary. the Cary with surface drives went In Out In Out. The Cary with TRS it went IN IN Out Out. Please forgive if I got the in/out wrong. Just look at the props.
HabanaJoe 12-14-2007 09:16 PM
On the Gancia we used to turn in - out / out - in so each side turned into each other. We had diesels, very heavy, fixed drives in negative trim with stepped bottom????
