-   -   huh????? (https://www.offshoreonly.com/forums/general-boating-discussion/175463-huh.html)
smokin' joe 12-14-2007 11:16 PM
Cats are pretty light on their feet, but I suspect forking in the tunnel...
Hot Duck 12-14-2007 11:31 PM
The forks are up between the sponsons.
Donman 12-14-2007 11:43 PM
Chris Angel is involved here somehow.
GO4BROKE 12-15-2007 08:32 AM
I thought only fountians had a layup that light. Helium infused carbon fiber.
Back4More 12-15-2007 08:37 AM
so a cat could be rack stored?
I would like to see a pic.
McGary911 12-15-2007 09:10 AM
Neat trick. It's all ball bearings.........This is the closest I could come to the same thing. With a little photoshop, I'd bet it could fly too......
http://i173.photobucket.com/albums/w...loat2Large.jpg
spazboz 12-15-2007 12:53 PM
This is kinda a funny angle, but in picture #2, wouldn't you see the yellow pipes, or at least the shadow of it by the golf-cart. Judging by the extreme angle of the golf-carts shadow from the sun (and/or other light source) Also, is the step in the concrete over there at different angles? Nick
CAP071 12-15-2007 01:04 PM
No Fork U you can tell it's winter. If it was june we wouldn't all be sitting here amazed at this picture :circle:
Hot Duck 12-15-2007 09:36 PM
It's absolutely on a fork lift. The forks go in about the same height as the gimbal on the drives, but they go between the drives and are hidden up in between the sponsons. Look behind the drives in the first picture. You can see the forks and the white rubber pads on the vertical part where the forks attach.
fund razor 12-16-2007 08:59 AM
Always a good sign when a 2007 has blisters.
