-   -   Mercury ID Tag on Motor (https://www.offshoreonly.com/forums/general-boating-discussion/176155-mercury-id-tag-motor.html)
Skeed UP 12-27-2007 08:29 AM
Where do I look for the Mercury ID tag on my motor? I am trying to find the exact year it was built. I found the block number on the back, but I do not see the silver tag. Would it be hid by the coupler?
MJ
dollerparts 12-27-2007 09:59 AM
mercury puts there serial # on the stbd side of the motor bracket. its 2 letters and 6 digits.then call a merc dealer and look online w/ merc for the year etc.
Skeed UP 12-27-2007 10:19 AM
Skeed UP 12-27-2007 07:14 PM
not there, I found 14096859 on the rear of the block and behind the cupler housing was M111 can this tell me anything.
Mbam 12-28-2007 07:58 AM
It's on the side of the block above the starter on Sterndrive & inboard (block mounted starter), can be a real pita to see depending on the boat.
dollerparts 12-28-2007 08:25 AM
if it was registered properly even the drive or gimbal serial # will work as long as its the original pieces
Skeed UP 12-28-2007 08:45 AM
Thanks I will check that when I get home.
Skeed UP 12-28-2007 08:46 AM
The engine and drive did not come together. The boat came originally with a 350 mag and I upgraded to a 502 Mag.
