Starting motors that have sat for years....need help >
Old 12-31-2007, 02:56 PM
Default Starting motors that have sat for years....need help
I am going to be trying to get a couple of Fresh water cooled 502's running that have sat for three years......where should I start.......
302Sport is offline
Old 12-31-2007, 06:09 PM
Registered User
Pull the plugs and squirt a penetrating oil in there- real well. Let it sit a day, then do it again. In a day or so, hand-turn the engines a coupe of revolutions. Then crank out as much oil as you can. Change the engine oil. Pull the pumps and look at the impellers. Check over all the fuel lines & electrics. Pump out the fuel from the tanks then fill them at least half-full- or run the engines from a remote fuel source. New plugs, filters, etc. Fire the engines & watch for obvious issues. Warm them up then run a compression test. That should do it.
I'd also take a good look at the outdrive boots.
Chris Sunkin is offline
Old 12-31-2007, 06:49 PM
Are these engines still in the boat or on a garage floor?
Were they pickled before they were stored?
Were the air intakes and exhaust outlets sealed shut?
Did the original owner wear briefs or boxers?
Edward R. Cozzi is offline
Old 12-31-2007, 06:56 PM
KNOT-RIGHT's Avatar
Glad to see ya still got ya sense of humor
KNOT-RIGHT is offline
Old 12-31-2007, 06:58 PM
Admit it...you at least smiled when you read it.
Old 12-31-2007, 07:02 PM
bouyhunter's Avatar
Banana Hammock
bouyhunter is offline
Old 12-31-2007, 07:23 PM
sunkin HIT THE NAIL ON THE HEAD ... follow that and you'll be in good shape ,whatever you do dont just try rolling it over and firing it on starting fluid or a shot of gas
Old 12-31-2007, 08:06 PM
might also pre prime the oil pump along with what chris stated
JPD Motorsports is offline
Old 01-01-2008, 01:22 PM
Question
Originally Posted by bouyhunter
Banana Hammock
Please explain this post.
Old 01-01-2008, 02:25 PM
KNOT-RIGHT's Avatar
I think he saw ya running around south Florida with one on
You have a pm.
Quick Reply: Starting motors that have sat for years....need help
