-   -   What's the best rust removal product and/or procedure for metal? (https://www.offshoreonly.com/forums/general-boating-discussion/178068-whats-best-rust-removal-product-procedure-metal.html)
handfulz28 01-22-2008 03:07 PM
More of a general question, anything from surface rust to good old salt water exposed iron that might still be usable. I know wire brush/wheel for the flaky, hard stuff. But I'm wondering more about chemical treatments like naval jelly, Rust Aid, and the different metal parts prep treatments that I've seen out there. I tried this recently: Evapo Rust and wasn't impressed. I just bought some ZEP Commercial stuff at Home Depot to try, but it seems like a lot of products are just Oxalic acid.
VetteLT193 01-22-2008 03:14 PM
the only thing I've ever found that actually works is a grinder. Some of that stuff will slow things down, but not stop anything.
CigDaze 01-22-2008 03:17 PM
Phosphoric Acid (Naval Jelly), but even that can be a pain in the azz.
Mechanical removal is the most effective.
tanner 01-22-2008 04:16 PM
Erusticator... Hydroflouric acid
jafo 01-22-2008 04:31 PM
Remove rust from the surface, then POR-15. It's the ONLY stuff that really works. Don't get it on you skin- it only comes off when it wears off! By far the most popular coating and treatment by car restoration experts.
handfulz28 01-22-2008 04:40 PM
That's what I'm looking for, not worried so much about coatings/treatments afterwards.
Erusticator...now that sounds good. :D
BY U BOY 01-22-2008 05:03 PM
you can knock the heavy rust off with a grinder then use a product called rust bond sealer.This is used in the offshore industry everyday and works wonders.I have used this myself with fantastic results.
It basically bonds to the rust and also creeps under the paint surrounding the rust to stop it all together. Then just paint over and be done with it.
Chris Sunkin 01-22-2008 05:16 PM
Rustoleum 3575 rust reformer works quite well but won't give you the film strength of POR or Chasis Saver (Chassis saver is equal to POR at less $$) Not a big deal if you're overcoating with a high-film 2-part coating like epoxy or poly.
The best device for removing rust from irregular surfaces is a pneumatic needle scaler.
handfulz28 01-22-2008 07:50 PM
2 Attachment(s)
Here's a couple examples of what I'm looking to work with. Nothing heavy requiring a scaler. Chemical/fluid application is what I'm looking for. One of my circ pumps died and leaked through the weep hole dripping salt water on the damper and surrounding area. So I'm also looking to clean that up.
pachanga 01-22-2008 07:56 PM
Looks like a machineshop Vat job to me!
